Monocote and Ultracote compatibility?
I want to uses some Monocote trim on top of Ultracote. How well does Monocote stick to Ultracote, and what is the best application method? Should it be applied with trim solvent, Windex etc or tacked with a iron and shrunk? Would it be best to apply trim panels prior to applying full sheet to wing etc? Any experience or help please.
Thanks in advance..........Nick
KS
I've used them in a combination for some time. Never had a problem that I can remember. I used trim solvent once, went back to spraying a little water on top of the base covering. I iron the trim pieces down, starting from one edge going to the opp. side. You have to let the steam out. Hope this helps.
