Super Sportster 40
My Feedback: (8)
WY
Super Sportster 40
I have a Super Sportster kit at my builders right now and is almost ready to cover. I had heard that Knife edge flight was not possible with the designed tail feathers so we re-designed the rudder(+2.5"" and elevator halves(+1.5"). The feathers are now a close copy of my 46 size world models cap 232 squared off not rounded. Any body tweaked there's in any special way to make it better. I would apperciate any suggestions before the monocote is unrolled.
CA
Super Sportster 40
I also have an original SS 40, still flying after 13 years, its on its 2nd O/S 46 engine. I took about 1/2 of the dihedral out when I built it, if I remember (I know I took out some ). It will hold a level knife edge as long as you want with the stock tail. It is fast with this engine and I'm sure that helps.
Super Sportster 40
This was the first kit I ever built. I built mine as per the plans and it flies great.
I am not sure how to pull off a knife edge - so I can't help you there!
Ted
Ted
