4*120
CT
4*120
If I were building a 4*120 with a 4 stroke in the recommended range would I need the high torge servos or would the standard futaba ones be ok? I do not forsee any radical flying or 3D type flying.
RE: 4*120
Standard servos are fine for a 1.50 or smaller 4-stroke. As long as your going to build it with stock control surfaces. If you modify the control surfaces and make them larger--then I'd put stronger servos in it.
CT
RE: 4*120
Thanx I was thinking of the Saito 150 on it.I am tossing around some ideas and this helps a bunch.Actually I'm thinking of parting with my Venture kit with all the goodies and going bigger with the 120.So many kits and not enough time lol. I'm trying to get things built plus the job and getting the house we just bought in order,man where does the time go?
