CA Hinge tools
CA Hinge tools
A quick question.
Fo a newbie builder, do the hinging tools sold by Dubro and others end up saving any time, or ensuring a good installation or are they just another method of releiving me of hard-searned cash. I have to order up a few things to get started on my first build and I was thinking of adding one of these to the list.
Dubro Hingeing tool
I also (think) I need a couble bar sanders (5.5" and 11") should I get two of each size for coarse/fine paper?
How about cutting balsa sticks for framig up tail-feathers and stuff, can I just use my #11 blade, or am I better off with a razor saw?
I already have medium CA and 5 minute epoxy so I will order some thin CA and 3 minute epoxy.
I am going to get a buildng board tomorrow, one of the guys at the local building supply store is a RC nut, he should be able to help me out.
I've run out and bought too many cool widgets that I've never used before - this time I need to make sure that I'm getting what I need only.
Thanks for your time.
Dubro Hingeing tool
CA Hinge tools
The DuBro tool is nicer than cutting slots by hand, but see if Santa will bring you a GP Slot Machine instead
Bar sanders almost are a must (although they can easily be made)
So is a razor saw!!! Most of the tail feather sticks I use a razor blade for, but there are a million places where a saw comes in handy.
Forget the 3 minute epoxy (I hope that was a typo) you need 30 minute epoxy, and THIN CA is a MUST if you're using CA Hinges.
You might try this one.....
MinnFlyer has it down pat. From practical experience I can not comment on the GP hinge cutter. I only read somewhere that it CAN (?), be a handful till you get it mastered. I would experiment on scrap first till you feel confident using it. I personally use the Harry Higgley hinge cutting tool. It worked great for me. Yes.... bar sanders a must. I save a lot of the light ply after punching out the parts. (pack rat) One thing you can make with these is small "sanding sticks".. Maybe 5 or 6" long and a few narrow ones up to 1" or so wide. I buy the stick on sandpaper from GP and just stick it to the ply and trim with a razor blade. ( you might want to spray some clear coat or make sure all dust is off stick so the paper sticks weel). I use a razor saw a lot. Trimming off servo arms, plastic control rods tubes, etc. Cutting thick balsa is very easy with a razor saw. I don't know what you will end up with for a building board but here is a hint if you use a ceiling tile. I "thought" my new work bench top was very level. I put down the ceiling tile and layed a 4 foot straight edge at several angles and found it had several low spots that ALSO showed up low in the same areas on my bare work top too. I got a stack of index cards, and started putting 3 or 4, (or more), in small stacks under the tile till it was perfectly level. In case I needed to lift the tile ..... I ran a long piece of scotch tape across all the cards to lightly secure them.
Good luck on your project..... lownslo
CA Hinge tools
MinnFlyer - yes that was a typo....
I could make bar sanders etc, but I have no wood working tools other than a power cut-off saw, a bow-saw, a Dremel clone and a swiss army knife. Now if you want to do a valve adjustment on a motorcycle or swap the clutch out of a Nissan Pathfinder, I'm all set, but as when it comes to little fidly bits o'wood, I'm empty handed!
CA Hinge tools
Well, I once totally designed and scratch built a 2 meter glider with no tools other than a razor blade and some drill bits (note: not even a drill... had to turn them by hand!). So anythings possible! In fact, I was thinking of starting a thread along those lines. Maybe I'll just do that.
My Feedback: (9)
CA Hinge tools
I always seem to be too late with help, but may help another builder. I have made a many hinge slot with a#11 blade and I have the scars to prove it! You can always get a hinge tool, but I would say a razor saw is a must. I have always been a tool nut and have faced the fact that too many is not quite enough.Good luck and keep a box of Band-Aids handy.AMA14958
CA Hinge tools
For the cheap bar sander, no need to be Norm Abrahms
Get get a piece of hardwood about 2-3 inches wide and 24 or so inches long. (If you go to home depot or a store like that, check out hardwood flooring, pre laminated. Lots of times the tongue or grooves on a piece are damaged and useless for flooring. Doesn't hurt to ask for it or at least pay a $1-2 cost)
Double sided tape at Walmart, $2 for 50 feet. Also get a roll of sandpaper $4 for 25 foot roll. You won't use the full width; probably half. Use the laminated side to tape the sandpaper to; and it's easy to remove but holds until you want it off.
voila, a cheap sanding bar with no woodworking.
Bob
Bob
TX
CA Hinge tools
The hinging tool I use is the Harry Higgley tools and a centering tool by Great Planes and Goldberg.
A flat hard sanding board is needed,can make or build,balsa saw is big help,as time goes on the tool supply gets larger,sometimes I think the tools breed and multiply when the lites are off.
