Ace Seamaster Kit
Ace Seamaster Kit
I am trying to locate a copy of the Construction Manual and Plans for an Ace Seamaster .40 Wing span 59.5" Length 54" weight 7lbs. If you can help [email protected]
Thanks Larry
Thanks Larry
RE: Ace Seamaster Kit
ORIGINAL: Oubiedubie
Thanks Larry
Hi Larry,try Model Flight's web site here in Aust. Click on to the Thunder Tiger section.They have the instructions to download.
Cheers,
Fearless.
Thanks Larry
Cheers,
Fearless.
I purchased an old Ace seadancer at a swap meet and having trouble with the CG. It is a 72" wingspan and I installed a Tower 75 engine. I have no manual. My GP balancer indicates 6 oz in the nose. It flies great with this weight but the nose sits so low in the water its hard to get up on step. I removed 3 oz and still have trouble in the water. This old kit does not have the hull lifters or spray rails like the new ones do. I considering adding these to help solve my lift problem. Any suggestions or ideas would be appreciated.
yorukcat
yorukcat
