mid star
MI
mid star
Hey all,
I need a little assurance/ advice from all of you. I will be ready to maiden my new mid star that I built this winter next weekend. I have been flying for 3 years now. I learned to fly with an Avistar. then I built a 4* 40 last winter and flew it most of the summer until I augered it into the dirt. I was very comfortable with the 4* and had no problems at all. As I said I flew it for the majority of the season with no problems. I was talking with my father in-law yesterday, and he told me that he thought the mid star would be "too much plane for me to handle" I happen to disagree with him seeing as how I could wring out my 4* quite nicely. My question is is the mid star that different from the 4* as far as its flying characteristics go? I have a super tiger .40 in it, so it should not too wild. Should I hang it up for awhile and go with another 4*? Let me know. Thanks!
BC, CANADA
1 Post
RE: mid star
Hello; I have built and flown 3 Mid-stars, wonderful planes. I prefer their flying abilities to the four star series. Mine had an OS 40FP, a Saito 45 then a Saito 50 in the last one, it now has an Enya 46 4stroke in it. the Mid star 40 is a very versatile plane, no surprises, but it will knife edge with the best. I prefer tail draggers, and built them all that way. If you can handle the 4 star, you won't have any problems with the mid-star.
MI
RE: mid star
Thanks guys! I really don't think I'll have a problem with it either, but when the father in-law speaks up I figure I'd better listen!
RE: mid star
If you can handle a 4 Star then the Midstar will be no problem.
They have basically the same wing and both were designed
by Bruce Tharpe.
IMO the Midstar is a better plane. It doesnt have some
of the bad habits the 4 Star has like bouncing on landing
and tending to float forever on approach. And you can
build either as tail dragger or a trike. I prefer the tail dragger.
The 4 Star flies a little faster and has a slighlty better
roll rate. Other than that they are about the same.
Mine has a TT46 Pro on it and I use it as an advanced
trainer for the student pilots I train.
Mike Hammer
by Bruce Tharpe.
Mike Hammer
KY
RE: mid star
What these guys said. And if you're still not sure of yourself, let a more experienced guy at the field check out your setup and balance. Then take it up for a check ride (if possible, with you on a buddy box). Maybe that's what your father-in-law is fishing for.
MI
RE: mid star
Bruno,
Maybe he is itching for a free ride with it. I think I'll deny him of it
XTOL,
In my opinion, there's no sense building it if it can't be a taildragger.
If this flies anything like my 4* did, this summer should be a lot of fun!
XTOL,
My Feedback: (13)
1 Post
RE: mid star
If your Midstar is balanced per specifications for/aft and laterally and your control throws are also within guidelines you should be OK on your first flight. Another tip would be to use a Robart incidence meter to get your ailerons as close to each other as possible. Do it with the radio turned on. Good luck.
RE: mid star
XTOL,
arrangement and replace with a Sullivan. The stock tail
wheel wire will break in short order. Other than that its
fine built stock.
I can make the nicest softest 3 point landings with mine
you have ever see. Always a crowd pleaser...
Now I want to drag mine out and fly it again. Only
problem its raining and sleeting and freezing rain here
in Illinois. Argh...
Mike Hammer
MI
RE: mid star
Mike,
I used the Sullivan tailwheel on this one. I made the mistake of using the stock tailwheel on my old 4*. I'll never do that again. I hear ya on the crappy weather. It's been pretty cold and windy here. I have gotten the chance to take up the old trainer a few times so far this year though.
TX
RE: mid star
My Mid Star didn't last too long. It may have been my lack of flying skills at the time, but I think it was because one of my solder joints on the ailerons came loose. Went straight to an Ultra Stick 40 and flew with no problems for about a year.
RE: mid star
I have a question, what are the throws you are using on the three control surfaces of the Mid-Star 40? I have one and haven't flown it in a while and can't find my instruction manual.
TX
RE: mid star
I think I still have the instructions. Will look when I get home from work and post the info.
Just went through my saved stuff and I don't have the Mid-Star book. Don't remember why I tossed it but still have the one from my LT-40 kit. Samsdad is getting ready to maiden so I'll bet he has the book.
KY
RE: mid star
Flyboy1958,
The manual suggests these throws for testing. No other measurements are given.
Elevator - 1/2" Up, 1/2" Down
Rudder - 1" Left, 1" Right
Ailerons - 3/8" Up, 5/16" Down
I could never find the CG in the manual. But it's indicated on the plans between 2 3/4" and 3 1/8" from the leading edge.
Hope it helps.
Hope it helps.
RE: mid star
One thing to watch out for...You CAN get too much elevator
throw on the Midstar. During my first season of solo flying on the
Midstar I would bump up the throws a little on each outing.
I got to the point that it would snap out of a loop. Of course
a snap in a Midstar is pretty mild. It was pretty much just
a roll out at the top of the loop. I didnt know what was
occurring so I got my instructor to fly it once to check it out.
He said it was fine. Just too much elevator. Toned down
the throw a bit and it was fine. Unexpected snaps are pretty
exciting for a new pilot.
All the other controls you can pretty much get away with
all the throw you can get get.
Mike Hammer
Mike Hammer
MI
RE: mid star
I have many, many old RCM's and EVERY Sig advertisement says the mid star is the perfect second plane! Fly with confidence if you have that much stick time on your 4*. Sometimes thats 99% of what it takes to fly a new plane!
RE: mid star
Such was my case. I had an excellent instructor and we used my
Midstar as a trainer. Its a plane you wont so easily get bored
with or outgrow so fast as with a typical trainer.
I still have mine and its still enjoyable to fly. Now that Im
a designated flying instructor for our club I plan on using
the old Midstar for advanced training flights.
Mike Hammer
MI
RE: mid star
Well guys, I took her out for the maiden on saturday. I got the Super Tiger .40 purring along nicely and taxied it around for awhile to get the feel for it on the ground. Once I got comfortable with that, I lined her up into the wind and let her rip. She traked nice and straight with minimal rudder input once the tailwheel left the pavement. She climbed out so nicely, I hardly had to touch the sticks! Once I did have to give it 2 clicks to the right aileron and three clicks up on the elevator. I just flew circuts for a few minutes to get comfy with it and then I did a couple rolls. I noticed that the roll rate is rather slow. Loops are no problems though. By then the sun was stating to get pretty low, so I brought her down for a landing. This is where this plane shines! She came down real nice. It didn't float nearly as bad as the 4*. She taouched the runway and rolled out perfectly! This is a very nice plane that I feel very comfortable with. I have since added more throw to the ailerons and plane on seeing what she'll do next weekend. Thanks for the advice everyone!
RE: mid star
Glad to hear you had a successful maiden flight...
Yes the roll rate on the Midstar is a bit low. Its got
a lot of wing. You can up the aileron deflection and that
will help some. But its adequate for the type of flying
it was designed for. I considered clipping the wing
on mine but decided against it.
The Midstar is also excellent for learning rudder
coordinated turns. You will notice that the tail
tends to hang a bit low in the turns. Just add
a bit of rudder to kick the tail out a bit and
you can make nice pretty turns.
Mike Hammer
Mike Hammer
