Sig 1/4 Scale Clipped Cub Cointrol Throws
My Feedback: (76)
FL
I am in the finnishing stages of completeing my Sig 1/4 Scale clipped cub. The only thing is I can not find any infomation any where on the plans or instuction booklet on what the throws should be for the ailerons and elevator should be. I would not want to have a problem flying it after all the work that went into this kit. Any help that anyone can give me would be greatly appriciated.
Al[img]
Al[img]
RE: Sig 1/4 Scale Clipped Cub Cointrol Throws
Al,
Set the elevator at 1-3/4" up/dowm and the Aileron's 3/4" up/down, set the rudder so it stops with just enough clearance to miss the elevator. You will love how the Cub fly's. After you get the initial flights under your belt you will want to set the throws to max travel to get the most out of the plane.
I have over 30 flights on my C/W Cub and it is the best flying plane that I have had. I have mine powered with a Magnum 120 4-stroke and equipped with Robart Landing Gear.
Later!!
Anthony
Later!!
Anthony
My Feedback: (76)
FL
Anthony,
Thanks very much. I have a Supertigre .90 2 stroke in mine and all 1/4 scale 144 oz servos. Thanks again for your help.
Al
Al
Al,
Here is a link to my build thread on my C/W Cub.
[link]http://www.rcuniverse.com/forum/m_2708451/mpage_1/key_/tm.htm[/link]
Anthony
Anthony
