If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    Join Date
    Dec 2002
    Gainesville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Wings strong enough?
    I am building my first full kit (only ARF's up till now) and I am curious how strong the wing structures need to be. I have been assembling the spars and ribs by tacking in place with thin CA and then hitting them with medium CA to really bond them. Do I need to do more than this to make these structures strong enough? Do I really need to be using epoxy to join these structures?
    Thanks for any help,
    Matt
  2. #2
    Join Date
    Nov 2002
    Albuquerque, NM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    That should be correct (tell me guys if I am wrong since my plane was built this way!). If you use epoxy, it will definately be very strong but you'll have a ton of extra weight.
    Quondo Omni Flunkus Mortati
  3. #3
    Flyfalcons's Avatar
    Join Date
    Jul 2002
    Bonney Lake, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Only epoxy needed in a wing is dihedral brace and the butt joint between the two halves. Use 30 min epoxy for that.
    Ryan Winslow
    Fly PAU!
  4. #4
    Join Date
    Mar 2002
    Terrell, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    you're doing it the right way,hi stress areas only need epoxy
    My opinions only;want to argue check with your spouse.
  5. #5
    MinnFlyer's Avatar
    Join Date
    Apr 2002
    Willmar, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ditto
    Mike B. AMA# 42400 www.gettingairborne.com
    Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
    \"Those are my principles. If you don’t like them, I have others.\" - Groucho Marx
  6. #6
    Join Date
    Dec 2002
    ASFSDFSDGAFAF, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi
    You have put in shear webs between the top and bottom spars haven't you ?
    Dave
  7. #7
    Join Date
    Nov 2002
    Southampton, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    White wood glue. strong, and soaks in, and is light weight. takes 24 hours to dry clear, but never failed me yet. CA is brittle.
    Al
  8. #8
    Join Date
    Aug 2002
    Jackson, TN,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've used a combination of CA and or carpenters glue. The CA works fine, and as noted placing your web spars correctly help. Epoxy on the wing halves only when joining. Remember, when you cover the wing ALOT of the strength will come from the covering job.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
