Building a Lynch's Hanger combat 2.7.
Hi
Would like to know if anyone has built this combat 2.7, and how did they like it? Also how did you like flying it.
Thank you
Handyandy
Thank you
Handyandy
IL
RE: Building a Lynch's Hanger combat 2.7.
Hi Handyandy2 did you build the COMBAT 2.7 and did you like the way it flys and do you have any pix i jest got one from a club member and thought it looked kool THANK flashnson
IL
I modified the plane and added five inches to the fuselage, doubled the ailerons, elevator and rudder. I am running a DLE 50. Plane weight ready to fly is 15.12 pounds. and yes i did separate servos for each elevator and pull pull on the rudder
