wing washout correcting
FL
THANKS FOR THE IMPUT. I USED THE 50 - 50 AMONIA AND WATER MIX, PUT THE WING IN THE JIG, CLAMPED IN THE CORRECTION, APPLIED THE SOLUTION TO BOTH THE INSIDE AND OUTSIDE OF THE BOTTOM SKIN, AND LET IT DRY OVERNIGHT. IT CAME OUT PERFECT. I DID NOT HAVE TO OVER CORRECT. I ADDED THE 2 DEGREE WASHOUT TO MY WING.
