lanier lazer 200 ??
IL
lanier lazer 200 ??
i just got a 1/4 scale lanier lazer 200 given to me and i'm rediong the plane i was looking threw the build book on the websight ang it sayes not to fly the plane without the struts on the tail the tail and stab is fully sheeted and it's strong does it really need the struts because who ever built it never put the struts on it any input will help thanks
NE
RE: lanier lazer 200 ??
If it says to use them I would.
I had the misfortune of filming a Laser 200 tail exploding in the air. It had the tail wires on it, but it still fluttered through them.
http://media.putfile.com/High-resolu...er-200-breakup
ORIGINAL: bobby crashes my planes
If there is lots of support for the horizontal & vertical stabilizers, you don't need the wires. Mine flexes a lot, without the wires, so I don't fly without.
The tank placement in this plane is high. Don't run with an inverted engine, but you'll be okay with the engine mounted sideways. Inverted, the carb is too far below the tank.
Good luck,
Dave Olson
IL
the turtle deck is the stock plastic one with no struts but the stabs are sheeted it's strong but i wanted to see what yall thought
