Inverted Saito .91 - any issues?
NC
I'm currently planning my first build project and I'm curious about any issues related to running a Saito .91 inverted. What issues will I need to be aware of or plan around? I've already put the RCU search engine through it's paces and came up empty.
WA
RE: Inverted Saito .91 - any issues?
I've run four Saito's inverted including the 91. The only key to it is to have the middle of the tank about 3/8 of an inch lower than the needle on the carb, this prevents flooding. Even if it means making the tank floor and landing gear mount lower, its worth the extra work to have a motor that starts and idles with no hassles.
