Balsa USA Super Cub Build
Reply
Old 12-22-2006, 04:54 PM
  #76
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Balsa USA Super Cub Build
And here's the full scale version.
Tony Hallo
Tony Hallo is offline
Old 01-08-2007, 08:22 PM
  #77
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's been a while since I posted any updates. After much debate we decided to install pull/pull on the ailerons as the full scale counterpart. I wasn't very happy with the access hatches I made for the aileron and flap servo so this was also a good time to correct these. The kit provides aluminum covers for the wing to simulate the wing fuel tanks so I decided to provide servo access under these covers, both the flap and aileron servo will be mounted near the root. Three CB Associates pulleys are used to direct the cables to the aileron servo. The control horns are fabed out of 18 gauge sheet steel and drilled like the full scale. Dubro 1/4 scale turnbuckles are used. The fitting on the control horn is a Dubro rod end turned down to simulate the full scale version, once the plane is painted, the turnbuckles will be locked in place with tie wire.
Tony Hallo
ID:	593923   Click image for larger version
ID:	593924   Click image for larger version
Old 01-08-2007, 08:32 PM
  #78
CK1
CK1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tony , Thanks for the pics . I have been contemplating the same modifications to my aileron and flap controls .
I am wondering where you got the cable pulleys and are they close to scale in size (mainly regarding the exposed part).
Please keep up the posts they are inspiring.
CK1 is online now
Old 01-08-2007, 09:09 PM
  #79
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The pulley will get covered with a cover as shown in the attached photo, also shown is a PDF of the cover installation. Thanks.
Check with Mark's Hobby Warehouse in Pittsburgh, PA he may have more in stock,
412-68RCFUN
Tony Hallo
File Type: pdf
Old 01-08-2007, 09:20 PM
  #80
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's some photos of the bottom of the wing. The flap control horn is moved to the flap hinge pocket. The original horn location is also shown in the photo.
Tony Hallo
ID:	593979   Click image for larger version
ID:	593980   Click image for larger version
ID:	593981   Click image for larger version
Old 01-08-2007, 09:27 PM
  #81
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a photo of the full scale flap control horn.
Tony Hallo
Old 01-11-2007, 06:11 PM
  #82
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While traveling on business today through Carmichaels, PA I stopped off at Brodak's Hobby Shop (The control line guy) and found a NOS set of Dubro 1/3 scale Cub wheels. These are the pneumatic style that's out of production. Even have the Goodyear name on the side and 8.00 x 4 markings. This will be a nice addition to the Cub. The tires provided with the kit (Right side of the photo) are foam filled and have a tacky glossy finish, the pneumatic tires look like the real thing. The packaging was faded and the original price was $30.80, they were marked the price down some time ago to $24.84 and I got 10% discount on top of that, not a bad invesment for $23.00! I bet they were happy they finially disappeared!
Where did the spell check go?
Tony Hallo
ID:	595760   Click image for larger version
ID:	595761   Click image for larger version
Old 01-11-2007, 09:24 PM
  #83
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The flap linkage is complete on the right wing, now I need to go back over the left wing and install the current control system, remove the previous installed hatches and redo the bottom cap strips in those areas. The wings are nearing completion and it will soon be time to marry the wings to the fuselage and fit the lift struts. I have ruled out metalic streamline tubing and will use the kit supplied spruce pieces. I'm brainstroming a differnt attachment method for the connections at the wings, any ideas out there?
Tony Hallo
ID:	595881   Click image for larger version
Old 01-11-2007, 09:30 PM
  #84
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When using the scale aileron hinge kit From Balsa USA the gap between the wing and the aileron/flap is rather excessive when done per plans. The instructions have you install a triangle shaped filler on the trailing edge. On the full scale, a formed alumium end cap is fitted to fill the gap.
I added a 3/16" filler piece and sanded a radius to close the gap.
ID:	595890   Click image for larger version
ID:	595891   Click image for larger version
ID:	595892   Click image for larger version
Old 01-11-2007, 09:38 PM
  #85
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are photos taken of the trailing edge on a J3 Cub.
Tony Hallo
ID:	595894   Click image for larger version
Old 01-11-2007, 09:55 PM
  #86
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To keep the wings off the workbench surface I made up these stands. The wing rests on the spars in the open bay area, the wing can be mounted from either side while working on it, when doing work like sanding, I use paper clips to hold the wing in place. I need these because the top of my bench is normally rather messy. I expect it will be a week or two before I finish off both wings, signing off until then.
Tony Hallo
ID:	595926   Click image for larger version
Old 01-25-2007, 01:59 AM
  #87
mancha
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
jumping into this thread.
our kit just arrived yesterday.
many future question!!
mancha is offline
Old 01-25-2007, 10:10 PM
  #88
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great, I hope I can help.
Tony Hallo
Old 02-10-2007, 06:36 PM
  #89
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I decided to use the original design for the upper strut connection, just couldn't come up with a better method, hopefully tomorrow I will get the fuselage back on the bench and finish off the bottom connection. The light is getting brighter at the end of the tunnel, I mignt be half way through. Till then.
Tony Hallo
Old 02-18-2007, 09:17 PM
  #90
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the strut connection at the fuselage, I made aluminum inserts tapped for 6-32 to receive the fork fittings. On the od of the inserts I machined a 40 threads per inch thread about .010" deep for the epoxy grab hold of. I used a mixture of 3 hour exopy and milled fiberglass to glue the inserts in.
I really didn't like the way the wing end connections came out so the next day I re-did them. I was talking with a friend a flee market and we were talking about the strut fitting on a plane he was building so I borrowed his design. A 1/8" brass tube is wrapped with .025" sheet steel, I was able to bend it around the tube and get a good fit. This was done in vice. The assemby was soldered together. The struts were saw cut down the center line to receive the end fitting. The fitting is held in place with #4 flathed screws and a mixtrue of epoxy and milled fiberglass
Tony Hallo
ID:	624546   Click image for larger version
ID:	624547   Click image for larger version
Old 02-18-2007, 09:21 PM
  #91
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a photo of the full scale.
Tony Hallo
Old 02-18-2007, 09:28 PM
  #92
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For the jury struts I made up scale fittings and replaced the orignal spruce jury strut with K&S streamlined tubing. The band is made from .025" sheet steel and center clamp is constructed as was the wing end fittings, 1/8" brass tube wrapped with steel and soldered.
Tony Hallo
ID:	624560   Click image for larger version
ID:	624561   Click image for larger version
Old 02-18-2007, 09:35 PM
  #93
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Full scale photos of the jury struts.
Tony Hallo
ID:	624564   Click image for larger version
ID:	624565   Click image for larger version
Old 02-20-2007, 07:16 PM
  #94
wolfinwisconsin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just wanted to know if you have any contact info for the "scale" tailwheel,i tried to lok up the company name and came up with nothing...i am enjoying your build thread and hope to see more soon, i am currently building a 1/4 cub and a scratch b29-130" span. you are giving me some great ideas by watching your build.
wolfinwisconsin is offline
Old 02-20-2007, 11:08 PM
  #95
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wolfinwisconsin
Try Mark's Hobby Warehouse 412-68rcfun, I'm sure he can get you one.
I'm at the painful stage of fitting everything together and final sanding, I'm not happy with the wing to fuselage fit so I'll be spending the next few days resolving this issue. I might just cover the wings soon, I will use Stits products for final covering and finish. I'm glad to hear someone is reading this post.
Tony Hallo
Old 02-20-2007, 11:25 PM
  #96
skylarkmk1
skylarkmk1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Tony,
Wolf is not the only one reading. I am building the RCM Supercub (May 98) enlarged to 1/5th scale (84" ws) and watching your thread to see if you have any hints that I can apply to my model. Thanks for starting the thread.
skylarkmk1 is offline
Old 02-20-2007, 11:57 PM
  #97
MadDriver
MadDriver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't worry. You have plenty of people watching!! I can't wait to see the finished product. Amazing build so far! If I ever gather the guts to do a scale project, the cub is the way I would like to go.
MadDriver is offline
Old 02-21-2007, 10:15 AM
  #98
rotccapt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i am also watching this thread because i am scratch building a 1/5 scale super cub off of the sig 1/6th scale plans (and yes i ment 1/6 scale) and i hove found some of you info invaluable.
rotccapt is offline
Old 02-25-2007, 10:38 PM
  #99
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well it's time to start covering, I could of waited a while before covering but I just wanted the plane to look a little different. I kind of getting tied of looking at it. The Stits covering when on just like the video. The most difficult place was the concave area at the trailing edge, it took a while to get the hang of things as this is the first time I have used this covering. The nice about Stits, if you make a mistake, just clean it off with MEK and start over.
Cut the covering to size, brush on the Poly tac at the perimeter, and stick it down. I only able to work on 8"-10" sections at a time before the Polytac dried out to much. This slows the progess somewhat as I had to wait a little while for the Polytac to grab before I could move on. It took about 4 hours to get to covering tacked down and another two hours to shrink it and apply a coat of Polybrush on the solid areas and the ribs.
The next coat of Poybrush will get sprayed, then stitching, tape, final coat of Polybrush, coat of Polyfill, and paint.
The wing is covered with one piece of covering, it get tacked down at the trailing edge, wrapped around the leading edge, tacked at the wing root and tip. The covering is allowed to crawl around the trailing edge when shrinking. The covering is not cut where the wing strut fitting are located until the fabric is shrunk, a little differnt from the normal iron covering process.
Tony Hallo
ID:	630005   Click image for larger version
Old 02-28-2007, 05:20 PM
  #100
Tony Hallo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Production has increased somewhat, the video from Stits instructs you to thin the Polytack by dipping the brush into MEK before dipping into the Polytack. The second wing I tried straight out of the can and found without thinning I could move along much quicker. Second wing is covered, might be down to 4 hours on this one.
Reply
Display Modes
