help finding Pica parts
My Feedback: (7)
Hello to all I'm looking for a replacement windshield for my 1/5th scale cessna 182 pica...
I e-mailed cox about it they told me they may not reproduce the plane again till 2008...
anyone know where I may find one
Thank you
Bridog
Thank you
Bridog
My Feedback: (7)
RE: help finding Pica parts
thanks Deadeye!
I was thinking about that but wasn't sure how close of a match they where maybe I'll just order one and find out if I have no luck with the Pica one...
If you have the old one, you can cut a duplicate from clear plastic. If you do not have to original, you can use paper, and make (cut and fit) a pattern, and cut a new one from plastic stock.
Bill, AMA 4720
WACO Brotherhood #1
Bill, AMA 4720
WACO Brotherhood #1
My Feedback: (22)
And last, but not least , you can pull one. Its pretty involved. I helped a friend pull a canopy for a giant Gee Bee QED. 1.) carve a wooden mold, 2.) Construct an oven from foil covered building material and one or two heat guns. 3.) clamp a sheet of acetate in wooden frame . 4.0 heat the acetate, ( can actually be done in the oven if the wife ain't at home), 5.) pull the heated acetate down over the molded block of wood. IT will cool in the shape of the windshield or canopy. Its tricky. It take a few tries to get the technique down and to find the right thickness of acetate. The canopy frame work generally isn't as sharp as the factory ones. You can actually take it a step further and drill holes and use a shop vac to really suck the acetate down around the mold, provided you build some kind of box.
This is really last resort or if you are scratch building and you absolutely know there is no canopy available. And it generally takes two people.
My Feedback: (7)
thanks for this info guys!!! Wow Pilotfighter that is some serious work to get a canopy ... I might have to try that just to see what it's like and lucky for me I don't have a wife anymore to nag at me about the oven!! '
actually I do have the original and maybe I should have posed this Question??? I need a new one because I got a bunch of overspray on it.. Is there anything I can get it off with that won't eat the plastic???? i think it's a combination of primer and ppg....
Bridog
Bridog
