View Poll Results: A poll
Voters: 24. You may not vote on this poll
Winter Build?
My Feedback: (17)
Winter Build?
What to finish first?
The GeeBee was given to me, with the wing and fuse in the bones, the both need work before I cover them. And i need to find dicent struts for them, the wire the plans say to use will be ugly, going for scale here!
The Zero was won at a raffle, got a Moki 2.1, all scale landing gear, and static displa stuff from Y/A.
TX
RE: Winter Build?
The GeeBee is a classic and every modeler should have one in his fleet. Some of the work has been done so you might be able to get a two fer. With a quick finish on the R-2 you may be able to take on Zero and make head way on both birds.. Good Luck with all your projects.
I will be starting the 33% SD from Hostetler plans as soon as the kit cutter is done.
