4 60 . extra 300 Goldberg , compare
RE: 4 60 . extra 300 Goldberg , compare
ORIGINAL: typhoonfury
what are the biggest differences in these planes?
weight and span are about the same
An Extra will tip stall, while a Four Star dips it nose like a trainer in a stall. An Extra will snap hard if too much elevator is given, the Four Star will simply 'mush out'. An Extra needs some speed on landing; while a FourStar floats in, slower than a trainer.
If this is your choices for a second plane, go with the Four Star.
Deadeye hit the nail on the head with this one, The Goldberg extra 300 is pretty dicile compared to the other aerobatic planes such as Cap's and edges and so on but can get out of control if not used to flying this type of plane. If you have some good flight time flying low wing aircraft I could not give a higher recomendation th the Goldberg extra 300 but if you don't, I would go with the 4*60 I love my Extra and is a pretty nice build and a nice kit with good instructions but so is the 4*
Dauntae
Dauntae
