Question about invasion stripes
CA
Can anyone give me some advice about how to put invasion stripes around the belly pan of my p-51? I used trim monokote for the wing stripes, but so far a dry run on the belly pan looks like the stripes will wrinkle due to the compound curve. Help Please.
Fresnoflyer.
Fresnoflyer.
RE: Question about invasion stripes
I used a combination of regular Monoktoe for the black and Sig Aerokote for the white when I covered my Herr 1/2A Mustang. It worked pretty good. You might want to look at Hangar-9 Ultrcoat though. I've found that it works well around odd shapes using either an iron or a heat gun. You should be able to put it over Monokote just fine. If you take your time and really work the Ultrcoat, it should turn out nice.
CA
thanks for the Reply....hey I noticed your from Clovis. I belong to the Maera club, I am trying to get my 51 finished for Saturday, we doing a static display at the Sierra Vist Mall. Maybe we'll see you there.
PA
When i did the stripes for my p-51 i actually made paper templates. I attached the paper and then took a seamstress tape to make a lineto follow with pencil to draw the stripe. When i took it off the fuse i had a template with the ellipse to cut out my monokote. I then attached that stripe and made another paper template being each stripe was going to be different. Hope this helps.
Maybe I'll swing by Sierra Vista. It's just about 2-3 miles from me. I'm supposed to be painting but I can convince the other half that I just really want to take her shopping.
