building the cub 1/4 scale, should i use Robart 690 1/4 Scale Cub Main Gear?
ID
RE: building the cub 1/4 scale, should i use Robart 690 1/4 Scale Cub Main Gear?
Take a look at [link]http://www.piperj3gear.com/[/link]. I'm going to try this gear on a 1/5 scale Cub. He ( William Wallace) makes 1/6 through 1/3 size gear. Nice to deal with too.
Best regards,
Bill
Best regards,
Bill
The Wallace Gear look very nice but from what I have heard they are not as strong as the Robart.
Anthony
Anthony
My Feedback: (24)
AR
I found the site. I believe if I buy any it will be robart. I wonder if they can wear out? Like within 100 flights? Or? I hate to spend that kind of cash on landing gear and it just wear out fast. Can I put them on later if I decide to? After I have it finished and flew it a while.
I have around 40 landings on my Cub and there seems to be virtually no wear. I have heard the wallace gear get a bit sloppy after repeated landings. The metal on the Robart gear is of good quality and appears to have been hardened. I did a little grinding on my gear to make the edges a little cleaner for covering and the metal was very hard. The only thing that will wear out is the O-Rings and you can pick them up at the hardware store, Cumban makes a great set of Bungee covers to fit the gear as well.
Later!!!
Anthony
Later!!!
Anthony
ORIGINAL: CubNut
Anthony
Anthony
As far as scale appearance goes, at least in 1/5 scale, the Wallace looks better, IMO. I don't have a set of 1/4 scale Wallace to compare to 1/4 Robart, but the gear mounts (the part that bolts to the fuse) are the same for the 1/5 and 1/4 Robart, which makes them too large for the 1/5 scale plane.
For the price difference ($25-$40), and looks, the Wallace gear is good enough for me.
