BALSA USA or SIG?
ON, CANADA
BALSA USA or SIG?
I just finished my latest 3d airplane(showtime). I am planning on going into scale flying. I have built numerous arfs and about 3 kits. I do like to build very simple and straight forward kits, making sure that i have a fun/stress free build. I want this scale model to be electric power!
I was looking at the BUSA 1/4 SOPWITHY PUP and also the 1/4 scale piper cub.
I also notice that sig makes a piper cub. Which is better? Should i got with the BUSA SOP or the cubs?
I said that i want to make this electric. i have already found the new GP 3600 12c batery. This is a nihm battery. I has thinking of have a over powered scale plane for some aerobatics. 24c are needed so i would by to of these packs. With a motor and ESC this would equal the wieth of a zenoah 26 including full 20 onze gas tank.
So what do you recommend?[>:]
RE: BALSA USA or SIG?
I'm currently building the wings for a 1/4 scale BUSA Nieuport 17. I've built SIG products in the past. I've been happy with the products of both companies. It probably just comes down to which features that you like best or which has the best price at the time.
If you are looking for a simple, stress-free build, avoid either of the cubs. I can't speak for the Pup, but both of those cubs are builder's kits.
However, the Sig 1/5 scale cub is an updated kit with laser-cut parts and excellent instructions. THis may be what you're looking for
ORIGINAL: mapleleafs
I would also suggest looking at LiPo batteries. LiPo batteries will cut your battery pack weight by about 1/2.
If you do not have a LiPo charger, SLK offers a "LiPo-Dapter" for about $40 so you can charge LiPo from your regular charger. I have a LiPo-Dapter and it works perfectly.
I dont know the new laser cut SIG, but the last plane i built was a BUSA Sopwith...... its almost a scrtch build proyect and theres a lot of left to choice or experience parts as fore my taste i would go with the sig witch i think is not as hard to build for a intermidiate builder (the sopwith is a beautifull plane to fly)
ON, CANADA
Hey thanks for the info, but i do not need so use lipos because they are to light. The planes recommend a zenoah 26. This engine weighs 53 onzes along with a 6 onze muffler. It also recommends a 16-20onze gas tank! this means the added up weight is 70-80 onzes. I would need to buy about .75 grand worth of lipos!
I think i will go with sig 1/4 scale clipped wing. this airplane weights about 15lbs. I am thinking of using the GP 3600 12c batts for juice, E-Flight 110 or 160 brushless engine, and a Castle Creations 85HV speed controller.
Die cut kits depend on the quality and age (sharpness) of the die for the accuracy of the parts. Older dies can "crush" the wood as they cut the part, leaving a splintered and uneven edge. Laser cut parts are extremely precise and generally fit snugly together like a well made jigsaw puzzle. Both Sig and BUSA have excellent die cut quality as a rule, so little problem there. I have to agree with MinnFlyer on the 1/5 Sig Cub, it's all laser cut and makes an excellent flying plane. The kit can be built as either full span or clipped wing, the plans include both. Between the two 1/4 scale Cubs, I prefer the BUSA due to the way the wings are designed as compared to the Sig. BUSA builds the wing center section as part of the cabin structure, Sig builds the center section into one of the wing halves, The 1/5 Sig Cub wings build like the BUSA 1/4 scale. On all of these, the wing struts are functional and support much of the wing load in flight.
ON, CANADA
Ok so i decided i am going to get the busa 1.4 scale cub. Does the kit include instructions for a clipped-wing version? I would also like to know what should be the largest prop that can go on this thin?
Scale diameter for a prop for a 1/4 scale Cub is 18 inches (full scale is 72 inch). and a G-26 will spin one just fine. Don't know about electric though. As far as clipping the wings, my plans don't show them, but mine is a fairly old kit, don't know if they've changed.
At any rate, it's a straightforward deal to clip the wings. Just omit the two inboard bays on each wing half. You'll have to shorten the wing struts accordingly, but the attach points for the main struts and the jury struts are the same for the full-span or clipped span.
Bill, AMA 4720
WACO Brotherhood #1
