pacer hinge glue on CA hinges into foam?
I need to put some CA hinges into a balsa sheeted foam wing. Has anyone ever used pacer hinge glue with CA hinges? if so how did it work? Any other opinions on what to use are welcome.
For CA hinges use ONLY THIN CA... NOTHING ELSE!
And read this:
http://www.rcuniverse.com/reviews.ph...ew&reviewid=55
And read this:
Im with Minflyer here. Dont know what pacer hinge glue is .
If you have any regard for the model, as Im sure you do, you need to determine what all apllications are intended, as you are.
I wrecked a nice plane due to pilot error regarding hinges, funny thing, all the warning sines were there, here everywhere except in my thick head.
