Telemaster 40 Wingtip
RE: Telemaster 40 Wingtip
Ok I been thrown a loop
On the Telemaster the wing tip is a Triangle that needs to be shaped the question I have is how it is mounted.
I know that it has to be mounted so it angles in towards the center from the top of the wing the triangle stock is the same size of the wing
I mounted it flush with the bottom and level with the front is this right it doesnt look right
Sorry about the first post hit enter key insted of shift
Thanks The only trainer I had done used precut lite ply angled out so I was not sure it looked wierd.
I did some shaping and it turned out good. Well that is till my wife saw all the wood shavings on the floor
