Sealing hing gaps
OR
RE: Sealing hing gaps
If you're not into competitive scale, just use some Ultracote or Monocote on the underside of the aileron/wing and stab/el junctions and on one side of the rudder/fin junction. There have been some good forums on sealing here in the past, but it just comes down to adding a full length strip of film, the same color as the color you used, to the underside of the surfaces (or one side of the rudder). Be sure it is ironed on to each surface and it allows the movable surface to flex without restriction. I recently finished a Sig Clipped Wing Cub and sealed the hinge gaps this way and it flies great. Most of our club members who have seen it fly remark about how aerobatic it is. Lee
My Feedback: (-1)
Most the time I seal like Lee but depending on the plane I sometimes cover the surfaces both top and bottom by using one piece of covering. Only reason for this is to keep the engine snot of A two stroke glow engine from getting into the gap. There are A number of ways, you can even buy hinge gap sealers that come in strips.
IN
OR
Using the one-piece covering method is a great way to do it. Another thought is to make up some Coverite hinges. Just cut two pieces appx 1-1/2" wide (or wider if you have a thick surface), pin them together glue side to glue side, then ask your significant other to sew a stitch down the middle, the whole length of the pieces. Then, before covering the plane, just use your sealing iron and attach the surfaces together. Be sure to keep the stitch right down the hinge line, and don't stretch it too tight so the movable surface won't bind up. Cut it to length and use a little thin CA on the end stitches. Be sure to paint the "up" side after hinging with some BalsaRite so your covering material will stick to the hinge material. Results in an inexpensive hinge, seals the gaps, and it's very strong. Lee
CO
Thanks guys, this will be a lot of help, this is my second kit build, so it been a learning experience, first build was a G.P. 60 trainer, this sig 1/5 cub has been great to work on
thanks
thanks
