swept back dihedral joiner
FL
I'm scratch building a low wing plane with slightly swept back wings and would like some advice on how to install the wing joiner.
Thanks for any input.
RE: swept back dihedral joiner
Some people use straight hardwood spars across the center sections on both sides.
I have also used a laminated dihedral brace with a bend in the middle. 1/16 aircraft ply bent to match the sweep and laminated (4 pieces) with epoxy works well.
I have also built many planes without a dihedral joiner. I used 6 ounce fiberglass cloth and 30-minute epoxy to join the panels. The largest plane I did this on was a 90" span, 60cc powered giant acro plane. I used to snap the heck out of it and never had a problem.
FL
Thanks Ed. I like all the ways you mentioned. Do you have a preference for a 2 stroke .75 powered low wing plane set up?
Fashion one out of aluminum stock... my sailplanes would have an aluminum joiner with a coiuple holes sandwiched between ply... the holes allowed expoy to tie the ply together.. you could put a slight bend in the joiner and retain all the strenfth of the aluminum.
Mike
Mike
If you scratch-built it, you should have designed it with a straight spar. Too late for that now, but something to consider in the future.
What I would do is to use thin plywood - Like 1/16" - and epoxy it in place with the necessary bend.
Clamp it, and let the epoxy set.
Then add a second, a third, even a forth if you think it needs it. Or maybe 2 layers on each side of the spar.
My Feedback: (18)
I actually used several (six I think) solid aluminum rods 3/8 in diameter if my memory serves me correctly. Each one was carefully bent to shape and the final resulting spar was epoxied into the existing dihedral slot. I had to sand the center section to have the right angle but it wasn't that bad.
PM me if you need closer pictures or further explanation.
Anthony
Anthony
