CG Cub / Ques about wing build
My Feedback: (22)
OK
In the instructions, page 15 number 3 says:
"for long wing, cut a T.E. filler piece from 11 - 7/8" sheet. Cut filler to fit from center of wing to center of rib 2 location, pin in place."
I'm not understanding what it wants me to do here. The picture does not make it clear either. Reading ahead there's no more mention of this filler. WHo has built this kit can you tell me what they're wanting me to do here please?
Thanks!!!
Grandad1
Thanks!!!
Grandad1
RE: CG Cub / Ques about wing build
You need to cut a piece of of tapered T/E Stock to fit from the middle of the wing joint to where your aileron starts. If you look at the plan you will see the piece runs from the middle of the trailing edge of the wing(where the wing bolts are located) to where the aileron's start. It has been many years since I have built this plane(built 3 of them) and to the best of my reccolection that is what it is talking about.
Good Luck!!
Anthony
Good Luck!!
Anthony
My Feedback: (22)
OK
Ok I'll look at that in the morning,It said too cut this from A pice of A sheet that is 11 7/8 in long and not from the Ailron stock.But that would make more sence too me thanks for the reply CubNut.
