drill size for tap?
FL
drill size for tap?
What size drill bit do I use to drill a hole to be tapped for a 4-40 bolt? I have heard that I should use a .0888 bit but what is that in fractions of an inch (1/16?)
George
George
drill size for tap?
George you need numbered drill bits, these are different size from standard drill bits. Harborfreight carries them. I need a set myself. If you look on your tap it will tell you what number bit you need.
drill size for tap?
If you go to www.harborfreight.com you can get an entire drill set, fractions, numbers 1-60 and letter drills, along with a size chart for about $30.00. I have found this set very usefull. They're probably not the best drills in the world but for the price they're great. plus I olt drill motormounts and other balsa/lite ply stuff anyway.
drill size for tap?
In a pinch, you can use a 5/64 drill bit. The hole will be a little smaller than .089 (.078125 to be exact) so it's about 10 - thousandths undersize (or about the thickness of 5 human hairs) but if you just wiggle the drill a little that will be gone in no time. In fact, just drilling the hole usually makes it 5 thousandths oversize anyway. (Can you tell I used to be a machinist?)
Just go real easy with the tap, and if possible, use one with only 2 flutes
