eagle engine mount.
LA
eagle engine mount.
i have great planes engine mount for my eagle, but do i need to get a break away plate so the engine is set at the right angle or is the great planes mount ok?
AR
RE: eagle engine mount.
i have an eagle i recently built... what size is yours? did you install the break away plate mounting rails? I believe the mount will be set at 0 degrees so you will have to put some spacers to give it the down and right thrust.
AR
OH!
Well it's really easy to fabricate. Let me know if you don't have the plans and i can send you a copy of that part or the specs if you need them. It will be a lot easier in the end than trying to adapt the engine mount. But if you really want to use the engine mount, then washers will do the trick.
AR
ok, i will bring it to work tomorrow and scan the break away plate with the dimensions and i can email it to you. Or if you want me to mail you a hard copy let me know. If you want to full plans, i will have to find out where they can make copies of them?
