If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 63 of 85 FirstFirst ... 1353616263646573 ... LastLast
Results 1,551 to 1,575 of 2124
  1. #1551
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Skybolt hangar and clubhouse
    gasayers,
    Now you can try a 13 x 6 three blades and make your model look more realistic.
    You may even find that you can reduce the idling by another 100 rpm.
    More mass and momentum with little extra drag (torque).
    Zor
  2. #1552
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Reasoning and making deductions is useful but there is nothing like prooving it.
    I deducted that two of the cells were shorted thus reading 2.8 volts.
    Ifeven only one had been opened I would have read nothing (open circuit).
    I unwrapped the package and measured each cell.
    Two were showing 1.38 volts which adds to 2.76 . Close enough to 2.8 V.
    Two were reading absolutelu 0 (zero); dead short.
    The replacemnt packs I bought are 2,000 mAh instead of 1,100 and are dimentionally smaller and lighter.
    That is good and they are NiMh most recent technnology.
    Zor
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1770604   Click image for larger version.
  3. #1553
    Cougar429's Avatar
    Join Date
    Apr 2008
    Tecumseh, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Zor, NiMH are good cells. Other than two planes with A123 packs they are all I run. Only negative I found is their self-discharge rate is much higher than NiCads.
    Club Saito Member # 787
    Club WACO Member # 243
    FA65, 82, 3 X 91, 2 X 100, 2 X 125a
  4. #1554
    Join Date
    Oct 2004
    Auckland, SK, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks, three blader sounds cool but speaking of scale zor any chance of some pictures and detail of you rigging? looks impressive and is the kind of detail I like. Particularly as my plane travels in one piece.
  5. #1555
    Join Date
    Apr 2009
    Alstead, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Cougar429
    Try Sanyo Eneloop NiMH Cells. You can get them from Batteries America among other places. They have almost no self discharge (90% left after a year or two I think it is). The also supposedly have a longer cycle life. They do not have as high a C rating so are not good with high torque power hungry servos but I have found that they work with standard digital servos like the Futaba S 3152. I am slowly switching all my planes over.
  6. #1556
    Cougar429's Avatar
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    u2builder, I tried one of their Eneloop 5 cell packs I picked up at the Toledo Show. Looked great, but died on the 4th charge. I was able to save and reuse the plug and cable. Still, very disappointing and likely very rare.
    gassayers, a 13/6 3-blade is a perfect combi for that size motor and will allow it to peak out. Your vertical may suffer just a touch, but the torque effects should seem much less than that larger diameter 14/6 you have now.
  7. #1557
    Join Date
    Oct 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks cougar, sounds like it's worth trying. It won't hover anyway with the 91.
    Regarding power supplies I've converted about 6 planes (including the bolt) to 2cell 900mah li + ubec, The results are far superior to any battery pack I've ever had. Lighter and last longer per charge and more predictable. imho i.e 900mah 2 cell lip = app 1700 mah eneloop 4 cell
  8. #1558
    Join Date
    Jun 2011
    Birmingham, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    quick question - did anyone else find the cowling a very tight fit?  I rebated the sides, top and bottom of the fuselage by about 1/16" so that the cowl would fit flush but it still wouldn't go back far enough to get the 6" prop drive to firewall measurement.   I couldn't take any more wood off as there wasn't enough left to keep the lip intact, besides which that would have resulted in a step down to the cowl.   I tried both the aftermarket fibreglass unit and the supplied plastic moldings but they were both the same size, as though my firewall was oversize to start with.
    I ended up slotting the bottom of the cowl so that it could expand by about 3/8" and patching it with glass and resin so it now fits flush with the fuselage top and sides.
    QQ#2 - did anyone need additional engine cooling measures?  Those inlets either side of the prop look a tad small to me.
  9. #1559
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    New final hatch installation.
    The picture illustrate the new hatch setup.
    Put the airplane upside down.
    Remove the tiny screw at the rear bottom center of the engine cowling.
    Loosen the screw at the center of the two springs that reinforce the landing gear ( a couple of turns).
    Turn the small aluminim plate 90 degrees.
    Slide the hatch forward 1/8" for its rear to clear the landing gear.
    Lift the rear of the hatch and slide it out backward.
    Voila ___nothing else to touch and the battery and fuel tank can come out as needed.
    Zor
    Edited to correct "typos".
  10. #1560
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Cougar429
    Hi Cougar429,
    The local LHS does not carry NiCd anymore in these kind of battery packs.
    I had no choice than pick up the NiMh.
    I bought both the 4.8 V and the 6.0 V .
    It will allow me to try 6 volts in the system.
    I will have to be carefull about the higher self discharge of the NiMh.
    I preferred NiCd because of the higher current capability but these NiMh are supposed to have high current capability.
    All remains to be seen and proven.
    Zor
  11. #1561
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: robc57
    Hi robc57,
    RE: quick question ___
    You are not alone with this situation. I have seen the same when I built mine.
    This kit had quite a few problems that have been discussed before in this thread.
    One fellow wrote at one time (quite a while ago) that he had no problems at all and that everything fitted perfectly. My conclusion is that he simply wanted to indicate that all of us were stupid and did not have the experience and dexterity of building a kit. He never proved his statements. It was not worth replying to him.
    After getting the fuselage panels tight and well glued against the firewall I could not push in the cowling far enough to get the 6.0625" distance (firewall to engine flange {prop rear face}) so I started sanding the outside faces of the fuselage. In that process and pushing hard on the cowling it started to split.
    My solution was as follows ___
    I used one inch wide fabric ribbon on the outside of the cowling and doped it so that one edge of the ribbon is flush with the rear of the cowling. I then put in a second layer of ribbon also doped on. That stopped any cracking of the cowling rearend. I now could push hard and do more sanding of the fuselage.
    The fuselage became too thin for my liking so I used more ribbon on the inside of the fuselage and epoxied it to rebuild the thicknes of the planking.
    I am happy and had no more trouble with that situation.
    Others may have or have had a different solution.
    qq#2
    It appears that your engine is all inside the cowling.
    I believe that these two openings are sufficient to keep the engine at normal operating temperature if you have at least double that area for the air to come out likely at the bottom rear of the cowling.
    I do not have this as a problem because my Saito 125 cylinder is exposed to direct airstream as well as the muffler.
    NOTE:
    Someone just requested a picture of the Skybolt with a three bladed prop.
    I will postsome pictures in my next posting for him.
    You will see my engine installation in that picture.
    Zor
  12. #1562
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Cougar429
    gasayers,
    A 14" dia prop is accelerating backward a cylinder of air having a surface of 153.94 square inches.
    A 13" dia prop is accelerating backward a cylinder of air having a surface of 132.73 square inches.
    Quite a difference of air mass even asuming the same prop pitch.
    Zor
  13. #1563
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: gasayers
    Hi gasayers,
    Her a couple of ;pics of the three blade appearance.
    This prop is a 15 x 7 on a Saito 125 but it should give you a good idea of the appearacnce.
    Zor
ID:	1771152   Click image for larger version.
  14. #1564
    Join Date
    Jul 2002
    Brunswick, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm flying a larger GP WACO YMF-5D on a Saito 125 and it's more than enough power. I can't imagine trying to fly a Skybolt with that big an engine on the front. My Skybolt has an OS 90 and flies great.
    I did have trouble getting the Fiberglass specialties cowling to seat all the way over the firewall, but it only took a small amount of material removal, but a lot of slow sanding all around to get it to fit.
    The cylinder head on mine exits the side and I opened up a section on the bottom of teh cowl to help with cooling. A rule of thumb I've heard is to have three times the exit air area as you do the intake air to help move the air through. Otherwise it will get trapped inside the cowl and won't flow or carry the heat out with it.
    Glad your not letting that guy get to you Zor. Darn perfect builders with no problems.
    Jaybird
ID:	1771156   Click image for larger version.
  15. #1565
    Join Date
    Apr 2009
    Alstead, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I also had trouble getting the Fiberglass Specialties Cowl to fit. Much careful sanding. I've got that big Saito 125 on mine but haven't flown it yet. I figure I can use as much throttle as I want to. It balanced well with the big Saito. Saito's are light and it takes a big one to put some decent weight up front. I put the Skybolt last on my list of maiden's because it is so nice I figured it would be last. And with the crappy weather and things coming up I am not moving very fast
  16. #1566
    Join Date
    Jul 2002
    Brunswick, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    They are light. On the WACO I had to move my 2100 mAh NiHm 4.8 volt pack from inside the radio compartment to the firewall, use the Harris Higley heavy brass jam nut and prop hub AND add a strip of lead weights off of the end of the motor mount on a bracket. A lot of work, but I had to get it balanced. My Skybolt has a mass of lead on a bracket off the motor mount as well, but I forget how much.
    The throttle stick is a good thing!
    I've flown with the Guildhall Fun Flyers of Vermont. Are they anywhere near you?
    Jaybird
  17. #1567
    Join Date
    Oct 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thanks for the picks zor. Love the skis, flying in the snow is real dedicated, however to be quite honest it was pictures of your wire rigging and how you've attached it I was hopping for if you don't mind.
    Cheers
    Glen
  18. #1568
    Join Date
    Jul 2002
    Brunswick, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You can always click the "Gallery" link near the top of the page and then scroll through all the photos that have been posted if you have the time. Zor's plane is a pretty distinct white with broad red stripes on the top and blue pinstripes on the bottom...and the maple leaf of course.
    You can also "search" the thread by putting "flying wires" in the search box.
    Jaybird
  19. #1569
    Join Date
    Jun 2005
    Houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've got the Fiberglass Specialties cowl on mine and it did take quite a bit of work to make it fit. But there was plenty wood that could be carved off. Once I finally got it sliding on I would check the fit carefully and then carve where needed with a razor plane. The chin block was where I removed the most material but it was plenty thick. By the time I got finished the front of the chin block was fairly thin.
    It can be made to fit, it just takes lots of carving and fitting.
    Dave
  20. #1570
    Join Date
    Jun 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm getting dangerously close to starting the covering.
    Here's how the cowl ended up after splitting the underside, opening it out and glassing over the gap
    I didn't like the way the dash panel was done so I faired it in with 1/16" sheet:
    and my u/c mount cover:
  21. #1571
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: gasayers
    Cheers
    Glen
    gasayers,
    I do not mind at all.
    It is always nice to help someone by showing what we do without telling them what to do.
    I have pictures but have to find them in my accumulation of nearly 5,000 pics.
    It might be faster to take new pics ___Hee! Hee! LOL.
    On my way to take new pictures.
    Watch for my next posting.
    Zor
  22. #1572
    Banned
    Join Date
    Feb 2009
    Ontario, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    gasayers,
    Here are five pictures showing the flying wires attachments.
    I do not know in which order the pics will load up so I will come back after posting and add explanations for the pics.
    Explanations will be here.
    There is 10 wires. Each side has 3 flying wires from bottom of fuselage to top end of the interfstrut and 2 landing wires.from the cabane rear to the front of the bottom of the interstrut.
    This is the same as on the full size Skybolts.
    Pic 1 (top left of the stamps below) show the flying wires at the top of the interstrut under the top wing.
    Note that the airplane is upside down.
    Pic 2 is a closer view of pic 1 .
    Pic 3 shows the flying wires attachment to the fuselage bottom. Each wire is adjustable with its own clevis.
    The alumnum piece to which the clevis are connected is a piece of dural alumnum that goes all the way across the fuselage bottom and appears the same on the other side. It is completely independent of the landing gear mounting.
    Do not get confused with the wires shadows due to the flash that was necessary to take these pics.
    Pic 4 shows the landing wires at the top rear of the cabane wires. A single clevis adjust both wires.
    Pic 5 shows the landing wires at the bottom of the interstrut front on top of the low wing.
    in this pic there is an illusion of a wire at the rear end of the interstrut.
    That is a flash reflection due to the gap of the aileron leading edge. There is only two wires attached to the front of the interstrut.
    Here and there you may have to stand on your head to keep things right side up.
    The little ferrules (alclad alloy) are hooked to the piano wires at top and bottom of the interstruts.
    Please anyone ___I do not need corrections on my selection of words. The importance here is to respond to the query and not to play semantics.
    Zor
ID:	1771264   Click image for larger version.
ID:	1771265   Click image for larger version.
ID:	1771261   Click image for larger version.
ID:	1771262   Click image for larger version.
  23. #1573
    EJWash1's Avatar
    Join Date
    Sep 2008
    Hoodsport, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: robc57
    Noticed your carbon fiber landing gear mod. Please share the details and specs.
    EJ
    Citabria/Decathlon Brotherhood #2
    Golden Era Aircraft #26
    SIG Brotherhood #145
    WACO Brotherhood #246
    A man's home is his castle, but a hanger is his sanctuary...
  24. #1574
    Join Date
    Oct 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks, Glad I asked for the pics. I'd guessed how the bottom was done but your system for the top of the struts is simplicity itself and far better than the series of holes and braces and clevises I was imagining.
    Cheers
    Jaybird thanks for the heads up, I had no idea the gallery feature was available. cool, very slow and didn't quite come up with the pics I was after. Couldn't see the top.
  25. #1575
    Join Date
    Jun 2011
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The U/C came from here as did the cowl. The carbon composite (ie a mix of carbon and glass cloth) U/C is not an exact match being a little taller, so Iraised the mounting plate in the fuselage by 1/2". After sheeting the underside and cutting out the U/C section, Iattached a 1/16" ply plate under the heads of the leg bolts and glued the removed section of sheet to that. I still need to line the holes in the under-undercart panel that give access to the boltheads.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
