Reload this Page >
Sig Wonder Designed by Bruce Tharpe - 2nd Build
Reply
Old 07-03-2007, 11:25 AM
foosball_movie
foosball_movie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sig Wonder Designed by Bruce Tharpe - 2nd Build
Well, I enjoyed Bruce Tharpe's Venture Kit ( [link=http://www.rcuniverse.com/forum/m_5723966/mpage_3/key_/tm.htm]See my build thread[/link] ) so much I thought I'd try another Bruce Tharpe creation, "The Wonder". This was designed under the SIG umbrella. I was looking for something that would go fast and I just happened to come across this kit at my local hobby shop.
Initial impressions:
The Venture kit spoiled me. I can't believe I actually have to punch the pieces out of the balsa wood and sand the edges. Come on!
Instructions look pretty thorough. Plans were folded (not rolled), but not a huge issue. I like that the entire plane will fit on my work table, unlike the much large Venture 60.
This is a fairly small plane (32 inch wingspan). It suggests a .10 to .19 engine, but I'm going to stuff a .25 into the nose.
I can already tell that this thing is going to haul a.b.c.d.e.f.g......
ID:	715693   Click image for larger version
ID:	715694   Click image for larger version
ID:	715695   Click image for larger version
ID:	715696   Click image for larger version
ID:	715697   Click image for larger version
foosball_movie is offline
Old 07-03-2007, 01:23 PM
foosball_movie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sig Wonder Designed by Bruce Tharpe - 2nd Build
Back from my local hobby shop. Couple of hundred bucks lighter and I have my engine, props, servos, fuel tank and servo arms.
Got lucky, because I ran into a guy that had built several "Wonders" and he filled me on what worked best for him.
So I'm going with an OS .25 FX engine and 2 HiTech Mighty Mini servos for the ailerons and elevator and a Mighty Micro for the throttle. APC 8x6 prop.
Then I ran into another guy that flies high-speed planes and he, along with the first guy, said to definitely get a radio with exponential capabilities. I currently have a Futaba 6ch Skysport 6YG that came with my Hobbico Hobbistar Trainer. I had been itching to get a DX7, so looks like that is next on my list.
Old 07-05-2007, 11:40 AM
foosball_movie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing is coming along. It's tough getting the sheeting flush with the leading edge. This picture is showing how I'm attempting to fill some the gaps that remained with yellow glue. I also thought the trailing edge sheeting was supposed to stop before the leading edge, instead of going on top of the leading edge. So I had to remove it and cut a new piece of sheeting. I keep reading posts warning about building the Wonder well or expect problems. So I went over every joint with Med-Ca hoping it makes it a little stronger.
Old 07-06-2007, 06:40 AM
yel914
yel914's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One trick I've used on sheeting is to brush yellow glue on both the ribs and the part of the sheeting that contacts the ribs. Let it dry, and then iron it down with an iron on high heat. Weighting the sheeting down with small bags of sand or shot after gluing also works well. It's nice to have a few techniques at your disposal. Can't wait to hear how it flys
yel914 is offline
Old 07-06-2007, 08:57 AM
gumhead
gumhead's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I loved my Sig wonder. Very fun plane to fly.
Just dont fly it in a thunderstorm [X(]
http://www.rcuniverse.com/forum/m_43...tm.htm#4320511
gumhead is offline
Old 07-06-2007, 10:26 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Wonder is a great airplane! But quitcherbellyachin about having to pop the parts out of their frames - Geeze, waddya want, an ARF?
Too bad you got the engine already, I had one with a 25FX and it was almost too much. Had to custom make a battery pack to stick in the tail to balance it.
Next time, I'll use a .10
It will still be PLENTY fast enough and with less weight, it will be more maneuverable
MinnFlyer is offline
Old 07-06-2007, 10:33 AM
gumhead
gumhead's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
os 15 cv-a is a perfect match for this plane
gumhead is offline
Old 07-06-2007, 11:00 AM
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one and originally had a Webra .32 in it. After about 6 flights, my nerves were shot. Put in an OS 20FP, and it was still pretty damn hot.
BTW, just bit of advice. Make the top and bottom in CONTRASTING colors! You can lose orientation on this little dude fast. And never, never, ever, look away from the model when in flight. It goes a long way in a short time. I know, you can pull the throttle back, but that's for weenies.
TLH101 is offline
Old 07-06-2007, 12:56 PM
johnnylwhite
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Speak'in of WEENIES Terry.....Who is that holding the bullet?
johnnylwhite is offline
Old 07-06-2007, 01:28 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: johnnylwhite
Greg had to hold it, if I remember correctly, you were too scared.[:-]
TLH101 is offline
Old 07-06-2007, 02:23 PM
dennis
My Feedback: (90)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built one and used an MVVS 21. Really did enjoy that plane. Not as fast as a diamond dust but fun just the same. Your better off though to buy a set of plans for a combat wing and build a jig and crank them out by the dozen. Then you can fly and combat till you can't stant the fun anymore.
Dennis
dennis is online now
Old 07-06-2007, 03:46 PM
MP3_tilaco
MP3_tilaco's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, I love my Sig Wonder too, I bought one of them in Ebay, it was parcialy builded and I finished it, I flow it in March and so far this day I didn't leave. I have builded 5 for my friends and they are very happy.
To my Wonder I used O.S. 25 LA and it's a bullet in the air, rolling and looping like crazy.
It is mine.
Its is from my son, I builded it from a plan, is very easy to copy and build.
I builded it for a good friend, it's has a O.S. 25 FX.
I builded it for other good friend.
Is mine after a bad crash in the field.
My last Wonder, for other friend.
MP3_tilaco is offline
Old 07-06-2007, 03:52 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MP3,
you are a building machine. I looked at your Corsair and Mustang build threads. You are a craftsman.
carrellh is offline
Old 07-06-2007, 03:59 PM
MP3_tilaco
MP3_tilaco's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ja ja, I love build, is like a psiquiatric drug...
Old 07-06-2007, 04:00 PM
foosball_movie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just wondering....
For those who have built the Wonder, how many made the "Standard" concaved type wingtips? The wingtips that the instructions say should be carved and then use a dowel with sandpaper to round off the inside of the wingtip. These look like they'd be rather difficult to cover. Can I simpy round off the wingtip like a normal plane? What are the flying advantages of using a concaved wingtip?
Old 07-06-2007, 04:02 PM
foosball_movie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
psiquiatric drug
This must be some crazy Chilean thing! Won't be maidening my Wonder on this.
Old 07-06-2007, 09:29 PM
MP3_tilaco
MP3_tilaco's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
je je, I love build is the best for the stress or a hard working day.
In all my Wonders I made this concaved wintips, is not hard to do I only use a good knife and a little bit of sand paper. For covering I used a small sealing iron (Trim Seal Tool)from Top Flite.
Old 07-09-2007, 09:29 AM
foosball_movie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Broke in my OS .25 FX engine Sunday. This engine screams, but the 4 ounce tank doesn't last very long. Topped out around 16,000 RPM.
Old 07-09-2007, 02:22 PM
MP3_tilaco
MP3_tilaco's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I lost my Wonder (snif) [] , I was fighting with 3 friends in my club when I crashed in the air, my plane fell from 60 m.
Yesterday I was all day in my crafts workshop and I have a new plane...
Old 07-16-2007, 11:37 AM
foosball_movie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll post some updated pictures of the wing once I'm able to move my arm after it has recovered from carving and sanding the wingtips.
Old 07-19-2007, 09:44 AM
foosball_movie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok. I've recovered. I decided to create traditional wing tips instead of the concave type suggested in the manual. Another pilot at my flying field built a Wonder and he just left the wing tips off, but that seemed a little too lazy. I think I'll try the concaved type next time and purchase a little more efficient carving knife and some coarser sandpaper to make things go a little quicker. 150 Grit Sandpaper didn't do a very quick job.
I decided to go with the Russian design. Deciding between the Russian and Patriot design reminded me of when Matthew Brodrick choose to be the Russians in the movie "War Games". Completed the ailerons and began the fuselage. The ailerons seem to fit ok and move freely. I forgot to roughen up the left side bearing before I CA'd it to the wing, so hopefully it will stay on.
ID:	726124   Click image for larger version
ID:	726125   Click image for larger version
ID:	726126   Click image for larger version
ID:	726127   Click image for larger version
Old 07-20-2007, 05:40 PM
MP3_tilaco
MP3_tilaco's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guau, your Wonder looks great.
I think the concave wing tips is not necesary but is fine.
I finished my last Wonder it was from plan, tomorrow I'll flying and I hope do a good combat in my club [>:]
Last week end I fougth and lost my first Wonder , I did a midair collision with a Shrike
That was great [>:]
Old 07-20-2007, 06:38 PM
gumhead
gumhead's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: MP3_tilaco
Guau,
That was great [>:]
COOL! [sm=biggrin.gif][sm=thumbup.gif]
gumhead is offline
Old 07-24-2007, 10:05 AM
foosball_movie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a lot of work done this past weekend. Finished the fuselage and sanded the entire plane. Ready to cover. I butchered the two wing pegs on the leading edge that go into F2 used to attache the wing. Any suggestions on how to reliably drill the two holes for these pegs? It's basically blind faith that the drill is going through the support inside the wing.
Also, does the aft portion of the fuselage need to be capped? I don't see a cap anywhere in the instructions or the plans. Should there be a big hole in the rear of the plane under the stabilizer? See attached pic.
And one more question. I am using a OS .25 FX engine. The fuel intake will be pushed right up against the fire wall making it almost impossible to reach the fuel line once the engine is mounted. The best idead I have for fueling is to use a syringe to put 4 oz. of fuel into the take through the fuel line attached to the muffler. Any other suggestions?
ID:	729114   Click image for larger version
Old 07-24-2007, 12:15 PM
blw
blw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Run a small length of tubing from the carb nipple. You can use brass tubing to connect the rest of the fuel line from there. Easy to separate for fueling.
blw is offline
