monocote vs. ultracote
I'm not aware of any real difference there.
I prefer Ultracote because of its multi temperature aspects which, to me, make it easier to work with. It also has more of a "painted" appearance than does the rather plastic shine of Monokote.
It is a personal choice, I've seen many award winning Monokote jobs and have friends who swear by it --- I find Ultracote fits my skills better.
My Feedback: (21)
Well, I just finished covering my first plane, an LT-40. I can definatly say that Ultracote made the job a pleasure. It went on great, you could peel it off and put it back on, and it shrinks nicely under the heat gun. I don't think I will try anothe brand, because this one worked so well..
FL
I usually use MonoKote but Ultracote is easier to work with, it seems to have better stretch characteristics and can be repositioned.
I have not noticed any difference in strength and my choice of MonoKote over Ultracote is just a weight factor (I find that most colors that I use Ultracote is heavier).
Check out this thread
check out this thread it had some good discussion on this topic
http://www.rcuniverse.com/showthread...686&forumid=59]
PA
I have used both, monocote first then ultracote many times once you try ultracote you will love it. it also trims over itself with second and third color schemes very well.
My Feedback: (12)
IL
I always used to use monokote but on my last plane I decided to switch. I received quite a few compliments on how great this covering job was. It was very easy to work and I'll never go back to Monokote.
