Goldberg Tiger 60 Deluxe Balance
OK...all you guys with access to the Carl Goldberg 60 Deluxe (the one with retracts)...
Can you share with me what your CG balance point ended up at, along with the all up weight? I've got a problem with mine even though it shows as being within the range of 3-3/4 to 4-3/4" back from leading edge. Also...are you balancing inverted or right-side up and with gear up or down?
RE: Goldberg Tiger 60 Deluxe Balance
First let me say I dont have the plane you speak of.. .but.. I believe you balance a low winger upside down and think you would want to balance with the gear retracted as that's how the majority of the flying will be done. (not inverted.. but with the gear up... those ca fumes are still making me loopy)
Mike
Mike
