New Builder /Input on Kit and buying framing materials
My wife gave me a Goldberg Anniversary Cub kit for our anniversary (Cute ,huh?) She said if thats not what I want to build my Cub from I can swap it for another kit. I've been eyeing this one, the hanger 9 and the Sig or ????. My Gramps had and flew a J-3 when I was a kid, so I'm another Yellow fiend. Anyway, kit Cubby wise, What do you guys think?
My other question is whats the best way to buy stock for a scratch built? Work out a cut sheet or is there a basic rule of thumb as to what should be on hand in the shop? And last but not least (for now) where to buy, is the internet the way to go? I live out in the bushes so dont want to have to be running to town a bunch for sticks.
Thanks for the ideas,
Jack
Jack
RE: New Builder /Input on Kit and buying framing materials
The Goldberg cub is a great kit. For a scale plane, the build is very straight forward and it flys excellent. My only recommendations would be to get a fiberglass cowl and try to beef up the landing gear. Here's mine from a few years back...
If you are a new flyer, I would put the cub on the shelf for a while. It isn't a trainer. When I first got back in the hobby about 18 months back now, I scratch built a 3D plane for my first. I had build a lot previously but never flown one. One of the guys at the club took it up and checked it our for me and said it was a good flying plane and to take it home and put it away and get a trainer. I equated a high wing with a trainer and picked up a Great Planes 60 size cub kit. I opened the instruction manual and the first thing I read in big bold print, THIS IS NOT A TRAINER. I checked with the guys at the field and they also stated that it would not be a good trainer. SO I went the ARF route and got a Explorer 40 for my trainer. It's long gone as well as two evolutions of it that I built from pieces. I went to a 4*60 and it is long gone. I replaced it with a second one and that an my scratch built are what I fly now. The cub is still in the box waiting to be built.
The one rule of wood stock for scratch building is that you will not have the piece you need, no mater how much you have. The best thing I can recomend is to plan out the model you are going to build and caculate what balsa and ply you are going to need. Then buy about 50% more of it along with some other sizes and shapes. If you are buying sheets, the 50% more will let you sort out some better matched pieces for your project. I had what I though was going to be enough wood for a life time from a buying out a guy that was retiring from the hobby. That was last fall. I just ordered out another $175 worth to get my stock back up. Man it goes fast. Keep a good selection of 1/4" square stock as well a 1/16 and 3/32" sheets. 12x48 sheet of 1/8 lite ply, a sheet of 1/16", 3/32" and 1/4" aircraft ply. a few sticks of 3/8 and 1/2 tri stock, a few tapered aileron pieces (get matched pairs), and add in a few 3/8 and 1/2 sq stock for leading edges and you should have the basics for a lot of 40 size planes.
When you are planning you purchase, I use some butcher paper and make some 3x36 rectangles. I can then lay out copies of the parts on that paper to get an idea of how much wood I'll need. Once I got my Rhino 3D, I do it in Rhino and then print out the layout and stick it to the sheets for direct cutouts. Any Cad program will work for that, even some of the free ones.
I have bought most of my wood from Lone Star. They have a good rep so far. As far a buying from the local hobby shop, it doesn't stock balsa. I was floored when I went in to buy the wood for my first plane. I was forced to use the internet at that point. I have a 14" band saw, and I have ripped wood from old shutters for spars at times. That wood is usually bass wood, and if the shutters are old, like the ones I pulled out of my house, they are really dried out and not likely to warp on you. Just for what it's worth.
Don
Don
I've always bought stock for scratch builds on an as-needed basis. That way you can never be sure how much you've spent on the thing. You want a hobby shop with a big selection of balsa, so you can get a proper weight for each application.
ORIGINAL: Campgems
It's not the best trainer, but it's the best Cub IMHO.
Make sure you build the clipped wing - some people tend to think that the clipped wing will make it too "Sporty" but in reality, the full-size wing was designed originally back in the 30's when engines weren't much more than a squirrel-in-a-cage, and it NEEDED that huge wing to get airborne.
Once decent engines were developed, anyone who could afford a better engine clipped the wings to a more "Normal" length.
I agree that the full-size Cub is a lot better trainer than the model Cub. In the air it's fine, but getting it up and down is another story.
John Agnew
John Agnew
