Singer 1.20 Build advise
PA
Hi all,
I just got my Lanier Stinger 1.20 kit and can’t wait to start building. Can anyone give me some advice of what to watch out for to help make my build go smooth? Any input would be greatly appreciated. Also the wing is foam and needs to be sheeted with balsa. I never did this before so let me know what glue to use and any tips you gat!
Joey V.
Joey V.
RE: Singer 1.20 Build advise
Joey,
I used Pacer Z-poxy Finishing Resin with great result. This stuff is made for just this as well as for fiberglasing. Check out my build, Lanier Extra 300 1/4 scale, where we do talk about sheeting foam core. Neither I had done this before but belive me it's nothing difficult to it.
http://www.rcuniverse.com/forum/m_15...tm.htm#4659167
LA
I have a Stinger 60 that I built, used leading and trailing edge sheating with cap strip then Monokote. Only used fiberglass to reinforce the fuselage at the wing saddle.
