Drill size
Drill size
A number 51 drill is .0670 inch. The closest fraction drill is 1/16 which is .0625 or .0045 smaller.
The number (and then letter) size drills fall in between the fraction sizes. The larger the number, the smaller the drill.
A good hardware store should have number drills if you want to be precise, otherwise just use 1/16 and wiggle it a little.
CA
Drill size
Originally posted by ZB50
Thanks Shark,
I need to find a conversion chart.
ZB
Thanks Shark,
ZB
http://www.engineersedge.com/drill_sizes.htm
-David C.
