Yet another Sig Something Extra Build
#376
RE: Yet another Sig Something Extra Build
Uh oh, Iron Eagle is on the SSE warpath again. Please share (again). I promise to do an SSE Redux thread after SIG supplies my LHS.
#377
ORIGINAL: SeamusG
I want to see how some of the mods work out in the air.
#378
My new SE is done, engine broken in, (OS55AX), and ready to maiden if we ever get another nice day in Detroit. I am including the photos. This is the second one like this. My friend has built several with these tips and the covering design. He calls it a "Flight Streak". I just can't stand that stock wing ending. If you look closely at the belly photo you will see the 3 mounting holes for the Sig Kadet rear landing gear. This and a duplicate front one is used to mount the 32" foam floats. With the SE, no water rudder is needed. You just use extra high rate rudder and a blast of power.
#379
ORIGINAL: maynardrupp
My new SE is done, engine broken in, (OS55AX), and ready to maiden if we ever get another nice day in Detroit. I am including the photos. This is the second one like this. My friend has built several with these tips and the covering design. He calls it a ''Flight Streak''. I just can't stand that stock wing ending. If you look closely at the belly photo you will see the 3 mounting holes for the Sig Kadet rear landing gear. This and a duplicate front one is used to mount the 32'' foam floats. With the SE, no water rudder is needed. You just use extra high rate rudder and a blast of power.
#381
Very Nice!
The wings look so much better when they are "finished".
I like the float setup I bet it is a lot of fun.
Another nice day, well I hope you get one but it looks as if winter is on it way, good luck with the maiden.
I ought to consider putting floats on mine, the last couple of times I was at the field we had standing water on the runway.
Have you noticed any changes in performance adding the wingtips?
#382
I am no expert, but my last SE had carved round tips and the performance was not affected. My friend has hundreds of flights on his SE with these tips and the performance is awesome. The amasing thing about these airplanes is that they perform the same with those huge floats hanging down. Loops, rolls, snap rolls, and whatever it will do on land gear, it will also do on floats. I have also flown mine in 20 knot winds that were sending others home. This is a great plane and a real tribute to the late Scott Christiansen. I love the idea of just throwing it all assembled in the car. It is truly a fuel and go airplane.
#384
ORIGINAL: SeamusG
I call it my ''giggles-n-grins'' plane.
Hey Maynard - what are those control horns?
#385
Thx Maynard - I'm in the process of building an older-school pattern Bridi Killer Chaos. I've collected the 1/8" CF rods for the elevator & rudder. I'm just shopping for the rest of the hardware.
Next kit will be my 3rd SSE!
#386
ORIGINAL: SeamusG
Thx Maynard - I'm in the process of building an older-school pattern Bridi Killer Chaos. I've collected the 1/8'' CF rods for the elevator & rudder. I'm just shopping for the rest of the hardware.
#387
Doers do - that's all there is to it. We have this really bad habit of making mental notes as to how we are going to do it better the next time! It's a priority that we will make time for.
#388
TX
Maynard,
It's hard to tell on your plane but these are the horns you're using, correct? I've been yhinking about getting some of these.
http://www3.towerhobbies.com/cgi-bin...?&I=LXEMF9&P=0
#389
The plane is a great design, very well laid out and a lot of fun to bash, I was just concerned that my wingtips and larger span may adversely effect the performance.
I like to build them because I know pretty much what they will take.
Also as far as factory built planes, I have found I can typically build lighter than they come out of the factory.
I can't do plastic covering that well, but I can paint.
#390
ORIGINAL: GhostRider32
Maynard,
Maynard,
#391
I used pull/pull on all surfaces except for the flaps, they are getting push rods. I think I will order up a pair of those horns to use on the flaps, I want to make sure the linkage for them is solid.
I used a True Turn 2.5 inch spinner to make up for the lightweight muffler, still I won't know about the COG for sure until the wings are done, but it is pretty close right now.
#392
TX
Yup, those are the ones. I shorten the connecting arm so I can mount the unit closer to the hinge line. That hole that the control rod end goes into needs to be on the hinge line. If you use those horns you will also want to use DuBro's plastic ''quick connect'' ends on your control rod. If you also want a ball joint on the servo arm, you will need to make up the control rods so you can have threads on both ends. I took special care to make sure that my tubes in the tail boom were dead straight so I have little friction. The 1/8'' carbon tubes are the stiffest stuff I have ever sen. I just put those through the tubes to hold them straight while gluing them in. I also used an elongated hole in bulkhead #4 and didn't glue the tubes there. That allows lateral movement as the servo arm tracks an arc as it moves. I would to aft mount those servos, but this airplane always comes out tail heavy. I have the 6 volt battery all the way forward against the back of the firewall and under the tank floor. I am using a chromed brass spinner nut and I still had to add 3/4oz. of lead on the engine mount. If I used the stock muffler instead of that MAC muffler I would not hsve needed the extra lead.
Maynard,
Maynard,
Thanks.
#393
The maiden flight went well. I had my friend that has built 3 "Flight Streaks" do the maiden and I stood by for big trim changes. I must have done my rigging homework as all it needed was 2 clicks of down elevator. Everything else was fine. I flew it next but not too long as I wanted to take it home and check everything out. My other problem was my cold thumbs. The temperature was 18 degrees but not much wind. Brrr. You know it is cold when you have to squirt lighter fluid into the intake to get the engine to start. That little 55 starts and runs great and has gobs of extra power for this plane.
#394
Glad to hear all went well!
18 degrees, I can understand why you didn't spend more time flying, way to cold for me to consider it was bad enough at 33 degrees being outside today (with a bit of a breeze).
It looks like winter has arrived to me.
#396
I used plastic outer tubes also, but my control rods are 1/8" hard carbon fibre. These are available from several places. Here is one...
http://www.darrolcady.com/Carbon_Fiber/carbon_fiber.htm I glue the rod ends in with thin CA. I tried JB weld and it did not hold. My Phoenix Extra 330 came with solid carbon rods and brass ends. They instruct you to use thin CA to attach the carbon rods to the brass ends. I picked some brains and found that no one had ever had a problem with their method. My landing gear is from SIG and is for a Kadet. The tailwheel assy. is a Sullivan. Ya sure don't use much of the stuff that comes with the kit. I really don't know if all those changes are necessary. I do know that our field is a bit rough, so the longer gear, good tailwheel, and those 3.25" tires are a big help. All the good linkage makes for precise control and the trim stays the same.
#398
ORIGINAL: SeamusG
Maynard - thanks for the link. Did you use an outer sleeve on your rod ends?
I just flew it again today. I did have to stop when the snow got heavy enough to reduce visibility. Oh well it was a bit warmer than last time. The weather here is going to be blizzard condition for the next 5 days, so I won't be flying. That control setup makes for a very smooth flying SE. On Jan. 3 I will head to Miami for 31/2 months. I belong to a club there also. I need to decide whether to take the new SE or my Phoenix Extra 330. Because I live on our boat down there, my room is limited. Tough life eh?
#399
Oops, I read your question wrong...I thought you were asking about the sleeves in the fuselage. I do use a piece of aluminum tubing CAd over the end of the carbon rod. This isn't necessary unless you screw the threads in a little. Don't go very far with threading the end in as you will split the carbon tube. The aluminum collar keeps it from splitting. I don't use the tube at the servo end of the elevator or rudder. If you do, your carbon tubes are trapped and won't come out. Although you shouldn't need to remove them, I still don't like trapping them in. Just cut the 2/56 rods with about 4" of bare end beyond the threads, rough it up with sandpaper, clean with alcahol, put a bead of thin CA on and shove them in until the threads touch the carbon tube. The links for the aileron servos need shorter rods so I glue the aluminum tubes on both ends and thread the rods in, but only 1 or 2 turns.
#400
Really stinks to be you, huh.
I should have been a bit more specific. On the aileron control rods it "appears" that there is a short sleeve over the end of the CF rod where the threaded 2-56 has been inserted. The Darrol Cady site shows the use of 5/32" alum being used over the glued ends of the CF rod to ensure that nothing "cracks" outward loosening up the threaded 2-56.
Ok, sail or power?
hehehe - you're response beat me to it!!
Ok, sail or power?
