GP Patriot 40 Kit Build
Old 01-29-2008, 08:08 PM
  #51
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GP Patriot 40 Kit Build
I will try to have it all..... The final build pics, possibly a video, and the maiden results.
So far, I think its going to be a rocket!!! [8D]
Mike
UkerDuker is offline
Old 01-30-2008, 05:01 PM
  #52
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm basically done. I just need to install the aileron servos and control horns. I think it turned out great. It should be easy to see in the air.
Mike
ID:	865437   Click image for larger version
ID:	865438   Click image for larger version
ID:	865439   Click image for larger version
Old 01-30-2008, 06:57 PM
  #53
phjoker
phjoker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks awsome. good job with the pipe install. Let us know when the maden is.
phjoker is offline
Old 01-30-2008, 10:42 PM
  #54
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got everything done and installed except the battery. Currently it weighs 6lbs 9ozs. This seems kind of heavy to me. What weights are typical for this plane?
I just need to install the battery and balance, then I should be ready to test fly. Everything works great. All surfaces move perfectly, and the gear are flawless. I think the covering scheme should be easy to see once it gets airborne. This has been a challenging kit. I just hope the performance is just as impressive.
Mike
Old 01-31-2008, 10:26 PM
  #55
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TOnight I finished everything. I installed the battery and balanced it. I moved the battery to get the balance right. No lead was added. Test flight on SAT. I have asked the "field cameraman" to video the maiden flight.
Here are the final build pics.
Mike
ID:	866653   Click image for larger version
ID:	866654   Click image for larger version
ID:	866655   Click image for larger version
Old 02-01-2008, 12:17 AM
  #56
hummingbird111
hummingbird111's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice work Uker looks great[sm=teeth_smile.gif][sm=thumbs_up.gif]
hummingbird111 is offline
Old 02-02-2008, 11:01 PM
  #57
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THis is a great plane. I thought I might have some performance issues due to the weight, but it flew great. I fueled up and started it up. I made two final needle valve adjustments. I was taching the prop at 15250RPM. This was with my OS-46AX, tuned pipe, 10.5x6 prop, and using 15% fuel. I had good white smoke. I taxied out and lined up for takeoff. The plane tracked very straight down the runway. It was airborne at mid-field. I retracted the gear and made my first turn. It has a wild roll rate. It also wanted to dive. I added some up elevator trim and left aileron. Now it flies straight and level. I made several high speed passes. The pipe sounds awesome. LOUD and overbearing!!
The wind was almost directly down the runway. After about a 5 minute flight, I started lining up for my approach. I dropped the gear. I made the first pass to see how it would slow down......at idle it bleeds off airspeed nicely. I did a go-around and lined up again for final. I had a nice cross-wind as the wind shifted. It came in a 30 degree angle to the center line. Over the runway I straighten it out and feathered the landing. The wheels were tight so it slowed down perfectly.
I'll say it again. This is a great plane, on the ground and in the air. It has plenty of speed when you want it and also flies good at slower speeds. I cant wait to build the Patriot XL.
Mike
Old 02-02-2008, 11:23 PM
  #58
DT56
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great looking Patriot!
Thanks for the build thread!
That C130 project is very interesting. Any details available for it?
DT56 is offline
Old 02-03-2008, 05:54 AM
  #59
gunfighterII
gunfighterII's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Uker,
Excellent!! Glad you enjoyed it.
gunfighterII is offline
Old 02-03-2008, 09:44 AM
  #60
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DT56-
Thats a Palmer plans 1/12th C-130. Wingspan 132", Length 98". I am building it based on the AC-130U Spectre gunship. It will have a working cargo ramp, onboard cameras, paratroopers, smoke system, working fowler flaps, retracts, all scale lights (Nav, strobe, & landing), 4 engine syncronizer w/onboard glow, and brakes. I think I got all the options. Its approx in its 14th month of construction. Everything is being documented here: http://www.rcuniverse.com/forum/m_4820908/tm.htm.
Mike
Old 02-03-2008, 10:47 PM
  #61
phjoker
phjoker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad you had a great maiden congrats and Good luck with the plane.
phjoker is offline
Old 02-05-2008, 12:04 AM
  #62
hummingbird111
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice maiden UkerDuker,, glad i was there to see --->>nice job on keeping your knees from knocking.
Old 02-05-2008, 06:27 AM
  #63
hummingbird111
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
UkerDuker,,, i am still undecided on my fuel tank, can you tell me what brand fuel tank you used? I know you told me it was 8 oz, but i am trying to fit the 11 oz Hayes tank in mine and it looks tight []
Old 02-05-2008, 10:11 AM
  #64
DT56
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: UkerDuker
DT56-
Mike
Thanks for the link!
DT56 is offline
Old 02-05-2008, 10:21 AM
  #65
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hummingbird,
I used an 8oz Sullivan tank. You will have to remove some of the balsa from the fuel tank cover to make it fit correctly.
Mike
Old 02-06-2008, 01:12 AM
  #66
hummingbird111
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok thanks ,, i found a dubro 10 oz tank that fit good,, couldn't find a sullivan[] no prob, i got the 10 oz to fit thanks again.HB-111
-------------------VAROOOOM!!!!!!---------->>>
Old 02-06-2008, 08:04 AM
  #67
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just be aware, a larger tank will require more "up trim". I had about 6-8 clicks of up elevator to get it to trim out during the maiden. You will probably need more at the beginning of your flights. I guess it will all depend on your engine fuel burn rate.
Old 02-06-2008, 09:12 AM
  #68
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: UkerDuker
I think it's worth putting the tank further back on (or near) the CG combined with a 4 oz hopper tank up front. No need to change the trim during flights.
vasek is offline
Old 02-08-2008, 10:13 AM
  #69
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hummingbird,
I think I am going to modify my Patriot. I want to add a simple speed break right behind the cockpit. It will be similar to the brake on an F-15.
I'll post pictures when I start.
Mike
Old 02-08-2008, 10:59 AM
  #70
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This plane flies very fast, but I want the option to slow down fast. Here is my solution. I love adding options like this. Here is my first cuts into the upper fuselage. I will use a standard servo so I can adjust the amount braking. I will put the control on my slider bar on my JR9303.
Mike
ID:	873121   Click image for larger version
ID:	873122   Click image for larger version
ID:	873123   Click image for larger version
ID:	873124   Click image for larger version
Old 02-08-2008, 05:01 PM
  #71
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.rcuvideos.com/item/M2YQ5894XSSPX7WN/received
Old 02-08-2008, 05:34 PM
  #72
SpeedBoy
SpeedBoy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
COOOOOOL [sm=thumbs_up.gif]
I never see some like that in a patriot before , if you can take some video once in the air , it will be very nice
Good job UkerDuker
SpeedBoy is offline
Old 02-08-2008, 07:29 PM
  #73
phjoker
phjoker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks like it will work out good. Do you have any pictures of the install how you
mounted the servo and what you used for lowering and raising?
phjoker is offline
Old 02-08-2008, 08:37 PM
  #74
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hope it works. I'm just trying to reduce my approach speed on landing. I simply cut out the brake fairing. I added an additional balsa block on the underside of the fairing. I install a roughed up control-rod that is bent into a slight curve, towards the belly of the aircraft. At the end of the curved control-rod, I screwed on one of the original aileron plastic pivot piece. The control rod was epoxied to a carved out "trench in the bottom of the fairing.
The mechanics consist of another short control rod with the aileron plastic pivot piece connector. This connector is screwed onto the 2nd control-rod. I used a GP easy connector on my servo arm. The servo is a Hitec thin wing metal gear. (HS-125MG). I mounted this to the former. I slid the (2nd) control-rod into the easy connector and made the necessary adjustments. The fairing is deployed and retracted using the slider on the back of my remote, instead of a 2/3 position switch.
TOmorrow I will test fly it to see how effective it is. It should make for some fun flying.
Mike
ID:	873511   Click image for larger version
ID:	873512   Click image for larger version
Old 02-08-2008, 08:53 PM
  #75
UkerDuker
UkerDuker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Everything assembled. Looks good to me!
ID:	873529   Click image for larger version
ID:	873530   Click image for larger version
ID:	873531   Click image for larger version
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
