08' Top Flite Bonanza Build
My Feedback: (16)
VA
Hey Guys,
I started on my bonanza tonite and am going to document the build on here its gonna go slow at first as i am finishing up my stinson reliant but when it is done i will be fully dedicated to the bonanza my setup will be
OS91FX w/ Jtec In Cowl Muffler
Hitec 645's on surfaces
Film covering (hate to do it but i hear this is a heavy bird)
here is the planned scheme i know i am a long way from that lol
My Feedback: (16)
VA
RE: 08' Top Flite Bonanza Build
started the plane by edge gluing 6 1/16"x3x30 to make them 1/16x9x30 then cut the tail sheeting from pattern on the plan doing the v tail leaves me 3 spare 1/16" sheets which i am sure will come in handy especially doing this bird with corrugations speaking of which got one down 3 to go for the tail its alot of work but will be worth it in the end i am basically doing the same thing that is done on the piper arrow i cut them as close to scale as possible but i am no master craftsman so it'll do. My wife says she wants to help with this one i couldnt believe what i was hearing haha more to come...and please i welcome tips and tricks so dont be shy fellas..
Regarding your comment about film covering, I originally covered my TF Corsair with Monokote.
After a terrain impact event a rebuild was required and this time I opted to glass and paint using a lightweight cloth. End result was that the rebuilt model was no heavier than the original.
Since then I have opted to glass and paint at least part of my later builds, including some quite small models. Main reason for me is that however much I try and seal the edges film always seems to lift somewhere sometime.
Just my $0.02 worth.
And by the way, how did you get the wife to help? What's the packback? (there's always one)
Terry
Terry
My Feedback: (16)
VA
ORIGINAL: Redback
Terry
Terry
My Feedback: (16)
VA
here is tonite TEDIOUS progress should be finish with tail corrugations tomorrow then onto framing the tail feathers i have some stuff for the stinson on its way from tower so this forum may be slow for a little bit as i am going to be covering but not to worry i will still be around
have just started building mine , was thinking of a zenoah g20/26 ei from zenoah
have tried to do a lot of research on the same but could not find anything on the www for the same
would appreciate your inputs
Is there a thread on here on how to do the corrugation like you are doing? I've got the TF Bonanza but have not started it yet. I've been looking over RC universe at all of the Bonanza threads. I should be starting mine in the next few weeks.
NC
That's what I was wondering. My TF Bonanza kit arrived the other day and I have been going around and around (and around) trying to decide which engine to use. I finally decided on the OS .91, but have had an even harder time finding details on an in-cowl muffler that would fit.
Grotesquebass, are you using a stock Jtec muffler or are they fabricating a custom unit for you?
I'm planning on using the O.S. 75 in mine. I've got the in-cowl muffler and I'm looking for the scale look and not the sound. That's one reason I'm not going to use a 4 stroke. The 75 has enough power to fly it and make it look scale in flight. I know some of you will disagree about the 75 but anything bigger will not fit inside the cowl unless you do a lot of custom work to make it fit. I should be starting my build in the next few days and will start a build thread.
