Dave Patrick Ultimate 120 lower wing plans
NY
Hello, I inherited a Dave Patrick Ultimate 120. IT was crashed and destroyed the lower wing. Since Dave Patrick is no longer in business. I cannot get a wing or plans so I will have to build from scratch. Is there anyone out there with the plans for a lower wing? I would need a diagram of the wing rib also, I understand that all ribs were the same size.
Thank you
Thank you
RE: Dave Patrick Ultimate 120 lower wing plans
Since it was an ARF (if it's the one I am thinking of), good luck with that. The original package woudn't have included a set of plans. If it was me, I would strip the top wing and copy the construction details since the top and bottom wings should be the same on an Ultimate bipe. Or build two new wings, top and bottom to ensure you have a matched set. Then it won't matter if they are identical to the original because they at least they are the same and that is what really matters.
Mark
Mark
My Feedback: (21)
ORIGINAL: mmattockx
Mark
Mark
