Reload this Page >
1970's scale kits
1970's scale kits
Old 04-23-2003, 09:24 PM
JRW
Default 1970's scale kits
Hi All,
I've come across two 1970's era kits. One is a B24D and one is P-38, both are "Royal" kits I believe. Does anyone have any information about these kit (good/bad)?
Jim Woodward
Old 04-23-2003, 09:33 PM
FLYBOY
FLYBOY's Avatar
Great kits. Royal now is sold I think by hobby barn or hobby shack as Martuka or something like that. They are expensive kits but great kits.
Old 04-23-2003, 09:59 PM
wfortney99
My Feedback: (310)
wfortney99's Avatar
Default Royal kits
I did not know Royal imported a B24D. Did you mean teh B25 ?
Anyway the P-38 is a well designed kit that ccan fly on one engine. But as with all Royal kits, it is a builders kit. However all that work was well worth it.
Royal kits were produced in Japan by Marutaka. FLYBOY is correct the current importer is Hobby Barn. Check them out at hobbybarn.com
Old 04-24-2003, 12:40 PM
MinnFlyer
MinnFlyer's Avatar
Great kits, but you can plan on building it as if you were doing it from scratch. If you're not familliar with the erm "builders kit", you will be by the time you're finished. LOL
A "Builders Kit" means you get a lot of wood (some of it is even cut out for you), a set of plans, and a few pieces of paper (that I won't even call an instruction manual) with instructions like:
Step 1. Build the right wing
Step 2. Build the left wing
Get the idea?
If you like a good building challange, they will produce an excellent airplane.
But if you're not someone that enjoys cutting, sanding, and making most of the construction decisions, they can be a nightmare.
Old 04-24-2003, 05:07 PM
wfortney99
My Feedback: (310)
wfortney99's Avatar
Default Builder kits
Yes Mike you captured it well. With a Royal Kit you get alot of balsa/ply you glue together, THEN carve, plane and sand the mass of wood until it resembles the picture on the box ! whew ....lots of balsa dust !
BIll
