Sig Fazer CG?
My Feedback: (264)
MD
Sig Fazer CG?
I am looking for help to find the correct balance point on my FAZER. I purchased this plane from a seller here on RCU and while I did get the instuction booklet from him, I did'nt get the plans and they have the CG range printed on them.
Will one of you FAZER guys help me out here?
I am eager to fly this plane.
Thanks, Mike
Thanks, Mike
RE: Sig Fazer CG?
My old set of plans indicate 5 inches back from the leading edge at the fuselage. I had this plane about 15 years ago and really enjoyed it. I could fly circles around myself as though it was a control line plane.
IA
RE: Sig Fazer CG?
Hi rcdude,
Here are the factory specs.
Set Up Specifications English Metric Directions
Elevator 3/4 inch 19 mm Up and Down
High rate 1 1/2 inch 38 mm Up and Down
Rudder 1 1/2 inch 38 mm Right and Left
High rate 1 7/8 inch 48 mm
Ailerons 1 inch 25 mm Up and Down
High rate 2 inch 51 mm Up and Down
Center of Gravity 5 1/8 inch 130 mm From the leading edge
Dihedral 0 degrees 0 degrees
Incidence + 0 degree wing, 0 degree stabilizer
Engine Offset 0 degree down, 0 degree right
