warped balsa
FL
warped balsa
I wouldn't worry about it too much. When you use the stuff, the structure should be able to brace it and remove the warp. But I wouldn't use it for sheet tail surfaces.
Make sure you store it flat. You may want to flip the stack over every week or so.
My Feedback: (9)
CA
warps
thanks for the info...i flipped the sheets against one another and strapped them to a flat surface until i get a chance to work on them...i also heard ironing them might work, so i was thinking...i have a friend at a dry cleaner....big steam tables...hummm...might work.....
