Reload this Page >
SIG MINI SMITH CG
SIG MINI SMITH CG
Old 03-23-2008, 05:12 PM
pa23180
My Feedback: (32)
Default SIG MINI SMITH CG
[8 Does anyone know what the CG location is for a Sig Mini Smith Bipe.
Old 03-24-2008, 11:11 AM
MikeL@Sig
Default RE: SIG MINI SMITH CG
Hi pa23180,
Here are the factory specs.
Set Up Specifications English Metric Directions
Elevator 5/8 inch 16 mm Up and Down
Rudder 1 inch 25 mm Right and Left
Ailerons 1/2 inch 13 mm Up and Down
Center of Gravity 1/4 inch 6 mm Back from LE on Bottom Wing
Dihedral 5/8 inch 16 mm On Each Panel
Incidence +0 degree wing, 0 degree stabilizer
Engine Offset 0 degree down, 0 degree right
Old 03-27-2008, 06:51 PM
pa23180
My Feedback: (32)
Thank you very much for your help. I got the model already built and it looks really nice. I want the test flight to be good. So again thank You.
