Mounting Elder 40 Vertical Stab
IN
Its time to finally put all these airplane parts together and finish my first kit! My only problem seems to be installing the vertical stab.. The darned thing will not fit into the hole!! on the planes it looks like I need to cut part of the horizontal stabs trailing edge out to make it fit.. Is this true?? It doesent seem like a good idea so I am waiting for seomeone with experience with this model to help me!! Thanks!!
IN
RE: Mounting Elder 40 Vertical Stab
Sorry I dont have a digital cam.. I dug around on the internet and found a few pics and I decided to cut part of the horizontal stab out and reinforce the area that I weakened.. I have the vertical stab epoxied on now and it looks great!! I cant wait till this thing flies!! building a kit is so much rewarding than assembling an arf!
I have yet to epoxy mine in place but as you can see from these pics I did have to remove some balsa to allow for the fuselage gussets but the stab slot fit as per plans. I wasn't worried about the sloting because the epoxy has a large surface to bond to.
Be sure to post your maiden info.
Don
Don
IN
Don.. Looking great!!! I didnt put those gussets on because I read a build thread that told me not to.. My mistake on the rudder was that I didnt have that notch on the trailing edge.. I cut that out and reinforced that corner with tri stock.. I got it all epoxied together and it looks great!! All I gotta do is hook up the radio and install the engine and its ready to go
ORIGINAL: aglaser
I have yet to break in the Saito 56 I'm using but that won't take long.
I love building but I have purchased my first ARF,,, the Four Star 120. I am going to use it to gain experience in that size low wing before I build my Spacewalker II. Also good way to get some time on my 125. If I'm going to crash I want it to be the ARF (:-)
Don
