Warped wing
Warped wing
While checking the incedence of the top wing on the GP Ultimate I'm building, I found that the left wing tip has a positive incedence of 1.75° and the right tip is down .25°. I want to try and twist the wing to correct the error. What is the best way to do this? I've been told that steam can help.
My Feedback: (287)
MA
Warped wing
I had a warped wing that was much worse. I went to a pal of mine and he wet the wing with a mixture of water and ammonia then secured it to a table and shimmed the warpes in the oppisite direction just a little past where you want it. Waited a few days and the wing was perfect. It has stayed that way for a couple of months now. I didnt believe it could be done. It was a completed d-tube structure. Hope this helps
Good luck
Brian
Good luck
Brian
My Feedback: (287)
MA
Warped wing
OK here it is.....take a spray bottle and fill it with water and about 1/4 cup ammonia. Spray the wing untill it is very damp. Then secure the wing to a table using clamps or weights.
Then using a shim start to straighting the warp. Now if the warp is......say a 1/4 inch you have to shim the wing back to neutral and then 1/4 inch in the oppasite direction! This should not be done in one step. Shim it in small increments and come back every couple of hours and shim it a little more untill it is where you want it.
Now you must wait a few days untill the wing is COMPLETELY dry. Do not accelerate the drying with heat or monokote gun. Once dry remove the wing from the board and it should spring back slightly and be straight or close to it. Repeat as necessary untill the wing is fixed.
Like I said I built a Fazer with a NASTY warp and this method worked for me. It was perfect the first try.
Good luck
Brian
Good luck
Brian
