question about a kit I'm buying
FL
Anybody have any knowledge about a "Gator" kit r/c Facination? It's a 120 size & I'm wondering if is a decent plane. I've got a GMS 120 just itching to power something. Any bad habits? How does it fly? Thanks Ed
RE: question about a kit I'm buying
If that's a Gator R/C Fascination, it is a fiberglass fuse, balsa/foam wing pattern plane. I believe it was an early 2M design. Your GMS 120 might be a bit light on power, depending on how overpowered you like your models. It should build to around 9.5-10lb with some care in wood selection.
If you want more info, hit up the guys in the main Pattern forum (not the Classic Pattern one), they should have a much more accurate account than mine.
Mark
Mark
My Feedback: (15)
Gator made the all wood fuselage version of the Fascination - PAC made the fiberglass fuse version. Both have balsa sheeted foam core wings. I have an OS140RX with pipe in mine. The GMS will not be enough. It is a great pattern plane, but not the latest and greatest. Probably designed in the early 1990's.
Kurt
Kurt
FL
That's the one I'm talking about Kurt. If my 120 won't fly it I don't think I'll get it , Thanks for the quick info guys. Ed
