Nosen Big Stik Wing
Nosen Big Stik Wing
I want to build a Nosen Big Stik, but the 100 inch wing span is intimidating as it is a one piece wing. What do some of you guys do to build the larger models? All I have is a 48 inch building board. I might be able to build the wing halves on it, but I don't have any flat surface 100 inches long to join the wings together. Lazer Works sells a short kit.
Mike
Mike
RE: Nosen Big Stik Wing
Just finished mine. Call Ed at Laserworks and get his short kit. Has a two piece wing, short kit comes with the wing tube, ply ribs and all fuselage pieces and formers. Great value, saves you a bunch of time. Good luck, Jerry.
