Painting balsa wood
Painting balsa wood
Hi Guys,
I have read a zillion posts about painting balsa and each one leaves me more confused than the other so i thought i'll write down what i understood and you guys can correct me if i am wrong.
I have this bare balsa fuselage:
1. Apply primer on the balsa wood (the ones used on cars. Hey I have one for wood surfaces called Primer Surfacer White. Will that be ok)
2. Allow it to dry
3. Sand
4. Apply second coat of primer
5. Allow it to dry
6. Sand
7. If smooth surface is achieved then paint. (I have synthetic enamel, is that good?)
8. Sand buff and then polish. (No idea how to do this and with what!!)
I am sure i have got it wrong so please tell me how to do it right!!!
2. Allow it to dry
3. Sand
5. Allow it to dry
6. Sand
Painting balsa wood
It is better to get a filler primer so you get the wood grain filled or use something like balsarite to fill the grain before you prime, or you won't get rid of the grain. It will not be easy to get rid of it all, but can be done. Another option is to use red devil spackle compound, (it is very very light), thinned with water and painted on and sanded to fill the grain before priming. Then prime and paint. Should work well. I use the spackel to fill fiberglass before priming. Use light sandpaper to sand it off and it gets smooth.
Painting balsa wood
Maybe I'm missing something here, but not covering the wood with something (other than paint) isn't a very good idea. Unless it's a very small free flight or electric maybe.
Balsa is extremely weak. Covering, whether it's Monokote or fiberglass or... is the only agent you've got to strengthen that fuse.
Painting balsa wood
Painting balsa wood
hy i have this bipe which was once painted ages ago by someone. I am recovering it. Some of the paint in the fuse has stripped off etc but the surface is like silky smooth. Can I just apply a coat of thinned epoxy over the fuse to seal it, then sand it smooth, apply a coat of primer and then use a automobile spray paint to paint the fuse and then use a lacquer to seal the paint?
Painting balsa wood
Comet:
Yes.
If you expect it to fly, though, that's another matter. You are heading toward a LOT of weight.
Do a good sanding job, put primer only on bare spots and sand 99% of it away. Where it's already painted primer is wasted, and the epoxy will be nothing but weight. Auto paints in themselves tend to be heavy, and most do require a sealer coat. Ordinary lacquer wont do though, it's not fuel proof.
Your best way, in my opinion, is just using fuel proof paints to start with. Quick, easy, the lightest way, and possibly cheaper than using the auto paint/sealer combination.
Bill.
Originally posted by cometravi
...Can I just apply a coat of thinned epoxy over the fuse to seal it, then sand it smooth, apply a coat of primer and then use a automobile spray paint to paint the fuse and then use a lacquer to seal the paint?
Bill.
TX
Painting Bare Wood
Its been My experience that a nitrate sanding sealer will provide an excellent base on bare wood. As mentioned earlier, dope and tissue works very good to fill the grain. Thats how a lot of ukie guys get that outstanding finish. Jim
MI
