Wood filler and balsa
Reply
Old 11-13-2008, 09:29 AM
06sportster
My Feedback: (7)
06sportster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wood filler and balsa
I am currently building a Sig Wonder kit. I have the wing about 90% done, and the instructions say to fill any pits/gaps with balsa filler then sand. I have some Elmers wood filler, would that be safe to use on the balsa? I do not see any reason why it would heart, or do I need something made especially for balsa?
06sportster is offline
Old 11-13-2008, 09:41 AM
Deadeye
Deadeye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Wood filler and balsa
The big thing is weight. You should be fine with the Elmer's.
Deadeye is offline
Old 11-13-2008, 09:49 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Elmer's is my first choice for wood filler. Go 4 it!
MinnFlyer is offline
Old 11-13-2008, 11:56 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
The best way to fill any imperfections on a balsa or glass fiber surface is to use brown micro balloons (phenolic= plastic )...Not white micro balloons... mixed with either polyester resin or 24 hour laminating epoxy.
ID:	1071393   Click image for larger version
jaka is offline
Old 11-13-2008, 02:11 PM
RICKSTUBBZ
RICKSTUBBZ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: 06sportster
.......... I have some Elmers wood filler, would that be safe to use on the balsa?
The elmers wood filler will get the job done. However, lightwieght "Spackling" works a lot better. You can find it at all the hardware stores. In the area of sheetrock supplies.
This stuff (spackling) is much lighter, maybe a little more stubborn to apply, but sands much easier.
By the way, neither spackling or wood putty offer any structural integrity. Epoxy and micro ballons will.
RICKSTUBBZ is offline
Old 11-13-2008, 02:15 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Personally, I'll take Elmer's any day over that Lite Spackle.
Old 11-13-2008, 02:36 PM
AviationNut
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I find the Elmer's to sand more easily than the lightweight stuff I've used. The lightweight filler seems to be harder than the softer balsa and isn't as easy to feather out as the Elmer's. Also, the lightweight stuff will bubble up if you apply too much heat when covering - really sucks for Monokote which needs more heat than other coverings.
AviationNut is offline
Old 11-13-2008, 03:35 PM
06sportster
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok, I am going to go ahead and just use the Elmers wood filler that I already have. I don't think any of it will be structal, just to fill in some boo boo's that I made. I may use some on the leading edge of the wing to help shape it too.
I just got my OS .15 CV-A. I spent a bit more on the motor than I had wanted, but hey its only money right! Going to be using a Futaba 2.4 reciever and 3 mini/macro servos (not sure witch ones yet). I hope this will be a good flying little plane. I have not build a kit in about 7-8 years. So I am taking my time, and trying not to mess it up too much.
Thanks guys...
Old 11-14-2008, 12:42 AM
AviationNut
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey, that's funny. I didn't notice that this was for a Wonder at first. I'm currently covering my Wonder myself. I went with a Magnum 15xls and Hitec HS-82MG servos on aileron/elevator and HS-81 on throttle. BTW, I thin the Elmer's with water to help make it easier to spread. Good luck with your Wonder!
Old 11-14-2008, 02:49 AM
bigtim
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
another suggestion for filler that works well and is very durable is the Minwax wood filler, I add just a bit of water to loosen it up a bit strait out of the can its a bit stiff,but with a little water its a superior filler and can be purchased at most paint or hardware stores.
bigtim is offline
Old 11-14-2008, 09:14 AM
Dsegal
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is a great engine for the Wonder. At my advanced age the plane with its extremely short tail moment was a handful for me but I stretched the fuselage a few inches and it was a blast.
Dsegal is offline
Old 11-14-2008, 11:11 AM
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
RCKen's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: MinnFlyer
I agree with Minn here. The Elmer's is all I use for filling on balsa.
Ken
RCKen is offline
Old 11-14-2008, 04:02 PM
06sportster
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: AviationNut
I never though of using water to thin it out. I did see that is said it was water soluble, I will have to give it a try next time.
Old 11-14-2008, 04:27 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, but it doesn't take much!
Just wet your finger before applying it. That's usually enough.
Once it's all filled rub a newly-wetted finger over it to smooth it out. Works like a charm!
Old 12-13-2008, 08:51 PM
Ram Jet
Ram Jet's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've had very good luck with a product made by Hobbico. It's called Hobbylite balsa colored Filler. It sands at the same rate as balsa, is water clean up until it sets and is very light weight. It makes for a nearly invisible filler on balsa.
Bill
Ram Jet is offline
Old 12-14-2008, 09:50 AM
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: RCKen
ORIGINAL: MinnFlyer
Ken
Me too, plus it's readily available at Wal-mart, and other places cheap!!
TLH101 is offline
Old 12-14-2008, 10:04 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I took Minn's advice on this and tried the elmers. I had always used light weight spackle in the past, but I'm a new convert.
It does not feather as well as the lightweight stuff, but it fills dings very well and gives a surface that you can ultracote too without melting.
Good stuff.
daven is offline
Old 12-14-2008, 05:33 PM
maynardrupp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use "durabond" 40 minute. This is a powder that can be mixed to any consistency and sands and feathes easily. It is a similar product to spackle but is used by drywall pros for the buildup coats. It is available at Home Depot and is pretty cheap. It only comes in a big bag.
maynardrupp is offline
Old 12-16-2008, 01:36 AM
flyathome
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is what I do. I use the Elmer's, but I thin it to a slurry with water and then thicken it with
microballoons. It is light weight, sands easily and is very cheap.
Steve
flyathome is offline
