4*60 throws
4*60 throws
Hi all,
The recommended throws for the 4*60, as stated in the instruction manual, are 3/4" up/down for elevator, 1" left/right for rudder, and 5/8" up/down for aileron. However, all the control surfaces are tapered i.e. the leading and trailing edges are not parallel. If one is to measure the throw at different points along the length of the control surfaces, they will differ due to the taper. My question is at which part of the aileron, rudder, and elevator do you measure the throws ?
Thanks...............Mike
