Piper Cub J3 1/4 - SIG or Balsa USA
#51
RE: Piper Cub J3 1/4 - SIG or Balsa USA
ORIGINAL: BelAirBob
SunDevilPilot,
I have my 1/4 Sig Cub already covered. Am I too late to modify for the Robart gear? I still am not clear on what you have to do to make it fit.
bob
SunDevilPilot,
bob
http://www.rcuniverse.com/forum/fb.asp?m=9510781
Hope this helps,
SunDevilPilot
#53
The sig is the way to go. The struts are functional. I have built two of the Sig kits and they are super quality and I think dead on tru scale. The sig will fly fine with a 4 stroke .90. Anothe choice is the 1/5 scale sig. To me this is the best Cub kit on the market and goes together like a Swiss watch. With it you will have the functioning fold down door and fold up window designed into it.
#54
Hi guys
I am planing to build a 1/4 scale piper as well.
It is still unclear to me which one to choose!?
I think the SIG has a more scale overall appearance where as the BALSA USA has a nicer cabin with smaller pillars and a functioning door!
Even though I see pictures of the SIG with a door as well. Is that been an upgrade??
I was wondering of either of the two models have been substantially upgraded in the last few years!?
On the website of Stewart Aircraft Corporation it says that the BALSA USA has been completely revised and upgraded.
Any comments or experiences from your side would be very much appreciated!
RGDS Martin
RGDS Martin
#55
Hi guysI am planing to build a 1/4 scale piper as well.It is still unclear to me which one to choose!? I think the SIG has a more scale overall appearance where as the BALSA USA has a nicer cabin with smaller pillars and a functioning door!Even though I see pictures of the SIG with a door as well. Is that been an upgrade??I was wondering of either of the two models have been substantially upgraded in the last few years!?On the website of Stewart Aircraft Corporation it says that the BALSA USA has been completely revised and upgraded.Any comments or experiences from your side would be very much appreciated!RGDS Martin
Go to this link... Cub Man has posted instructions on how to do the door / window mod on the sig cub
http://thecubden.org/j3l4-related/op...oor-and-window
John M,
#56
The Sig kit wasn't upgraded... the door / window mod you have seen on other sig 1/4 scale cubs was done by the builder... the door frame has to be re-enforced, preferably during the build... I'm in the process of cutting out the door on a already built 15 year old cub... its a bit more tedious doing the door after the fuselage has been built, but not impossible... I'll be posting some images on the ***Cub Brotherhood*** thread when I finish prepping all the bits an pieces... right now I have the right side fuse almost ready to glue in the re-enforcement wire, then I will move on to the left side fuse and re-enforce that side... then I'll be able to go back and cut out the door and window on the right side and then remove the 2 formers that the re-enforcement wires replace... then the cockpit will be free of any obstructions and can be fitted out with the interior.
Opening Door and window. ? The Cub Den
John M,
John M,
This is Gerry. I came across your thread about adding a door & window to the Sig 1/4 scale J3 Cub. I wish I had came across your thread sooner, I've already cut & built the door & window. I knew I needed to reinforced where I cut the right side frame out for the door & window, but didn't think I needed to add 5/32 piano wire to help reinforce that area. Do you have photos of your project of adding the door & window to your already built Cub? I know it's been about 4 years when you were doing that. My Cub is still in the building process, but of course I've gone passed that part of the build. I'm close to being done, the fuselage, wing, tail section are all done.
I'm adding floats to this plane, so I still have that to do. The hardware for installing the floats are already added to the fuselage.
I would love to see some photos, if you have them posted on here for the door & window project, I would like to see them. Can you point the way for me. I've been looking on here for your photos you said you were going to post, but I can't find them. Any help would be appreciated!
This is where I'm at in my build, the door & window is built, but need to do the reinforcing like in that article you posted. Thank you for that.
