Reload this Page >
Attaching a Canopy
Attaching a Canopy
Old 03-20-2002, 09:21 PM
DIsaacks
Default Attaching a Canopy
Okay lets hear the best method for attaching the Canopy to a plane. I seem to always screw mine up.
Old 03-20-2002, 11:03 PM
Dave Barrow-RCU
I like PFM for attaching canopies.
Old 03-21-2002, 12:00 AM
Mendes
Mendes's Avatar
I screw mine up too....
with servo mounting screws!
I really like using screws instead of gluing the canopy down, that way if I ever need access to the area under the canopy I don't have to tear off the canopy. I have used RC-56 glue with great success though, it holds very well.
Old 03-21-2002, 12:54 AM
aero
RC 56 is what I've used with no problems.
Old 03-21-2002, 01:55 AM
JERRY RCIA
THE BEST WAY I'VE FOUND IS WITH LOW TEMP COVERING MATERIAL SUCH AS ULTRACOAT. CUT A STRIP ABOUT 3/8" WIDE AND POSITION 1/2 THE WIDTH ON THE CANOPY AND THE OTHER 1/2 ON THE PLANE AND SEAL WITH A COVERING IRON. THIS MAKES A VERY NEAT INSTALLATION AND IT'S EASY TO REMOVE THE CANOPY IF YOU SHOULD EVER NEED TO. I LEARNED THIS TRICK FROM A MASTER BUILDER AND HAVE NOT SINCE USED ANY OTHER METHOD. DON'T WORRY ABOUT MELTING THE CANOPY MATERIAL, JUST SET THE IRON AT LOW TEMPERATURE.
Old 03-21-2002, 02:29 AM
BigBird1
Clear double sided tape....remove the backing from one side stick it to canopy...place on fuse...gently remove the backing from the other side and it should stick to the fuse as you remove the backing..
Never met a Chaos I didn't like...
Old 03-21-2002, 02:34 PM
Hisham
Hisham's Avatar
What ever you choose do not use CA
cause while setting white residue will stick
to the inner sides of your canopy ! :thumbdown:
My friend lost his plane (spinned into the ground)
as his canopy ejected away~
Keep it secure!
Old 03-21-2002, 02:52 PM
BigBird1
Keep it secure!
If ya wipe it down on the inside and outside with Pledge first...
and the take a Q-tip and Alcohol wipe along the glue line...to remove the wax it won't show the fumes..
Old 03-21-2002, 03:40 PM
AV8TOR
I too have used RC 56 but I think I still like Zap A Dap A Goo best.
Old 03-25-2002, 02:35 PM
Dutch Guy
Depending on what you are working with here's a nice one if it's wood.
Take the canopy, window or similar and make it oversize (around 4 to 5 mm) to the place it is supposed to be (the frame of the window) Take the oversize window and hold it against the spot where it is supposed to be. Take a pencil and draw a line arond the window. Take the window away and take out the excessive material in the frame for the thinness of the window plastic.
Take the plastic window and drill 1mm holes in it 5 or 6 will do on a flat surface (going around curved will take more little holes)
Take the frame and clean it up. Now make 5 min epoxy glue and put a thin line in the "cutout" in the frame. Take the window with the holes and put in place gently pushing it in the glue. Now take some puns and stick them thru the holes into the wood (all the way). Leave them there for the next 30 min and you can take them out. Carefully sand the frame down to the plastic and you are all down. Flush windows in a wooden frame and NO problems.
The Dutch Guy
aka
Old 08-11-2002, 02:20 AM
EDsnead
My Feedback: (10)
Default Fourmost canopy trim
I'm surprised that no one has mentioned Fourmost
They make a canopy trim that works great.It's a triangular length of rubber with a slit in the middle..Slide the canopy into the slit and glue the trim to the fuselage----simple.
Try it --you'll like it.
WWW.Fourmost.com
Old 08-12-2002, 05:25 PM
lennyk
My Feedback: (12)
560 works quite well, my plane fell over and even broke the pilot's headoff but the canopy still stayed stuck
